SOLVED: Set True Tone, Auto Brightness, and Brightness Level (Display Settings)
  • January 30, 2024
  • 28 replies
  • 424 views
I've spent some time researching where these options are actually stored, and found them in all locked away in
/private/var/root/Library/Preferences/com.apple.CoreBrightness.plist
This file is editable by all users, as it simply stores the current display tone and brightness settings. The only trick is, this file is only read at startup, so editing it does require a restart afterwards. For our computers labs and classrooms, we simply run this script at every login. That does mean, however, that if someone changes the display settings, it takes two restarts to get them to go back to our desired default settings (if someone can figure out what service or process to restart to force the preferences to update, that would be great, but for now, this solution is working for us).
Update: I have discovered that in order for this to work, you also need to have opened and closed System Settings. I will be working on finding a way around that. For the time being, we have simply added commands to launch System Settings and then restart the computer to our policy, and we only run the policy after hours so that our lab and classroom computers start every day with the correct display settings.
For those who are interested in our solution, here is the script that I wrote up:
#!/bin/bash ########################################################################################################################################################## # # Set Display Settings # Written by KClose # Created: January 30, 2024 # # Sets the default Brightness level, Auto Brightness option, and True Tone option. # The plist is only read upon startup, so changing these settings via this script will not take effect until the first restart after the script is run. # ########################################################################################################################################################## ### FETCH VARIABLES ### # Set empty variables trueTone="" autoBright="" brightLevel="" # Fetch True Tone option. if [[ $4 == [Nn] ]]; then echo "True Tone will be disabled." trueTone="0" elif [[ $4 == [Yy] ]]; then echo "True Tone will be enabled." trueTone="1" else echo "True Tone option will not be changed." fi # Fetch Auto Brightness option. if [[ $5 == [Nn] ]]; then echo "Auto Brightness will be disabled." autoBright="false" elif [[ $5 == [Yy] ]]; then echo "Auto Brightness will be enabled." autoBright="true" else echo "Auto Brightness option will not be changed." fi # Fetch Brightness Level # The recomended value at the time this script was written is a real number between 3 and 525. # This value was derived from an M1 iMac. [[ -z "$6" ]] && { echo "Brightness Level will not be changed."; } || { brightLevel="$6"; echo "Brightness Level will be set to $brightLevel"; } # Fetch Current User currentUser=$(echo "show State:/Users/ConsoleUser" | scutil | awk '/Name :/ { print $3 }') # Fetch GUID of Current User userID=$(dscl . -read /Users/$currentUser/ GeneratedUID | awk -F': ' '{print $2}') # Shortcut the PlistBuddy command for convnience. plistPal="/usr/libexec/PlistBuddy" # Define the Configuration File locations. configRoot="/private/var/root/Library/Preferences/com.apple.CoreBrightness.plist" # Fetch ID of Primary Display displayID=$($plistPal -c "Print :DisplayPreferences:" "$configRoot" | grep "= Dict" | grep -v AutoBrightnessCurve | awk '{print $1}') ### MAIN SCRIPT ### # Set options in the root Plist [[ ! -z "$trueTone" ]] && { $plistPal -c "Set :CBUser-$userID:CBColorAdaptationEnabled $trueTone" "$configRoot"; } [[ ! -z "$autoBright" ]] && { $plistPal -c "Set :DisplayPreferences:$displayID:AutoBrightnessEnable $autoBright" "$configRoot"; } [[ ! -z "$brightLevel" ]] && { $plistPal -c "Set :DisplayPreferences:$displayID:BrightnessLevelNits $brightLevel" "$configRoot"; } exit 0
  • January 31, 2024
 Hi there, does this work on ipads?
Thanks
  • January 31, 2024
Thanks
Unfortunately, this is for MacOS only. Scripting is not an option for iOS devices.
  • February 12, 2024
Upon further testing, while this worked flawlessly on my test system, it seems like it is inconsistent at best in practice. I will continue to work on this at my leisure, but Apple is not making this an easy thing to enforce.
  • February 27, 2024
This is useful. Thanks. I found the same plist because I needed Auto Brightness to be off due to our colour-calibrated computer labs. (True Tone as well, but almost no one is working here that late.) Because setting the brightness value has been the biggest improvement we are looking at (returning it to the value at calibration time), we are testing "brightness" (https://github.com/nriley/brightness) and Outset to reset the brightness at login time. It uses APIs, which means the change happens immediately upon run.
I'm presuming the reason `defaults write` isn't being used here is because we don't know the display ID.
  • February 27, 2024
"Defaults Write" could be used, I'm sure, but I am a fan of PlistBuddy, so I tend to start there unless there's something I can't do with it. You would still need to use a "Defaults Read" (or some similar method) to find the correct Display ID. Otherwise, in my experience, PlistBuddy and Defaults are fairly interchangable.
  • May 28, 2024
I get an error "Set: Entry, ":CBUser-C02B2E82-A6D5-463F-8001-EAC91E5D406C:CBColorAdaptationEnabled", Does Not Exist" when trying to set the True Tone (only).  Any ideas?
  • May 28, 2024
I'm honestly not sure. Because the "primary" display seems to receive a random ID, I can't be sure. It took a lot of work to source out all of the files and IDs, and honestly it still never worked quite right.
  • May 28, 2024
Thanks, I THINK I figured it out.  I've never used PlistBuddy so it took me a while to decipher what you wrote.  It seems the CBColorAdatationEnable key doesn't exist in the plist until it's changed so modified through the GUI:
[[ ! -z "$trueTone" ]] && { $plistPal -c "Add :CBUser-$userID:CBColorAdaptationEnabled integer $trueTone" "$configRoot" 2>/dev/null; $plistPal -c "Set :CBUser-$userID:CBColorAdaptationEnabled $trueTone" "$configRoot"; }
A reboot is required to get the setting to take... I'm sure there's a process that can be killed instead of a reboot but to be honest I'm not that bright to figure these things out.
  • May 28, 2024
Ah yes. You definitely have to use ADD or SET depending on whether the value exists first or not.I will frequently wipe out an entire plist and then I can use ADD for everything, but that didn't work in this scenario.
As for killing processes, I killed a *lot* of processes trying to aim for the correct one and never found it, so I had to use the reboot to get it to take.
  • May 28, 2024
[[ ! -z "$trueTone" ]] && { if ! $plistPal -c "Print :CBUser-$userID:CBColorAdaptationEnabled" "$configRoot" 2>/dev/null; then $plistPal -c "Add :CBUser-$userID:CBColorAdaptationEnabled integer 0" "$configRoot"; else $plistPal -c "Set :CBUser-$userID:CBColorAdaptationEnabled $trueTone" "$configRoot"; fi }
  • May 28, 2024
Did some more digging:
1. A log out will do
2. sudo killall corebrightnessd and sudo killall WindowServer
  • July 31, 2024
@kacey3  What do you set the empty variables to at the beginning of your script
trueTone=""
autoBright=""
brightLevel=""
  • July 31, 2024
trueTone=""
autoBright=""
brightLevel=""
These are intentionally empty and are not intended to be filled. These same variables will be set by parameters, but if a certain parameter is not set, we still need an empty variable later in the script.
  • July 31, 2024
Thanj you.  Everytime I run it manually for testing I get the following results and nothign changes
  • July 31, 2024
Are you setting the parameters in the script in the policy?
  • July 31, 2024
duh!!!  thanks. that was it.  however the when running the script, the settings change for a split second then revert, even when killing the corebrightnessd and Windowserver processors.  Any thoughts on that?
  • July 31, 2024
This is the script result
  • July 31, 2024
I found that it only ever worked after a full restart... and even then, it was inconsistent at best. I mostly used it for setting the options once, but then they never really stuck if someone changed them manually later.
Sorry I couldn't be of more help. This is one of those projects that I put a lot of effort into, and then was kind of defeated by Apple in general.
  • July 31, 2024
Understood.  thank you.  by chance did you see the screenshot I posted with the error message?
  • July 31, 2024
This was my final script based on @kacey3 's work which is working for me.  I only use it to turn off TrueTone:
trueTone=""
autoBright=""
brightLevel=""
    trueTone="0"
    trueTone="1"
    autoBright="false"
    autoBright="true"
### MAIN SCRIPT ###
#[[ ! -z "$trueTone" ]] && { $plistPal -c "Set :CBUser-$userID:CBColorAdaptationEnabled $trueTone" "$configRoot"; }
#    $plistPal -c "Add :CBUser-$userID:CBColorAdaptationEnabled integer $trueTone" "$configRoot" 2>/dev/null;
#    $plistPal -c "Set :CBUser-$userID:CBColorAdaptationEnabled $trueTone" "$configRoot"; }
    fi }
  • August 1, 2024
trueTone=""
autoBright=""
brightLevel=""
    trueTone="0"
    trueTone="1"
    autoBright="false"
    autoBright="true"
### MAIN SCRIPT ###
    fi }
Thank you. unforntuately I cannot get it to work.  it disables true tone, the screen color changes, but then in a couple seconds reverts back.
  • August 1, 2024
And you're using the script parameters?
And you're using the script parameter?
  • August 1, 2024
Yep..same as the screenshot above that @kacey3 posted.
Truetone gets disabled and the screen color changes, then after about 3-4 seconds it slowly reverts back to the "yellow" true tone color.
  • August 1, 2024
Maybe you have another policy (from your testing) or config profile that's changing things back?
  • August 2, 2024
unfortunately no.  this mac is running in our jamf sandbox testing server that literally has nothing on it.
