Hi, I browsed through several forums before posting this. I created a dmg file that contains the Sophos Installer.app & Sophos Installer Components folder.
My policy places the dmg at to /private/tmp/Sophos.
Then a script runs to install it:
/private/tmp/Sophos/Sophos Installer.app/Contents/MacOS/tools/InstallationDeployer --install
It would constantly fail on High Sierra. I came across the article regarding how Deploy Studio changes the permissions on the Library folder, so I fixed that by added a script to fix the permissions at the end of my workflow.
That works fine.
I also have a Configuration Profile which allows Sophos as an allowed Approved Kernel Extension.
Everything seemed fine until Sophos 9.6.7.
Now after all of that it fails with:
Error writing: (/usr/local/bin/SophosUpdate)
"The file SophosUpdate couldnt be saved in the folder "bin"."
I even tried adding these lines to my install script:
sudo chmod a+x /private/tmp/Sophos/Sophos Installer.app/Contents/MacOS/Installer
sudo chmod a+x /private/tmp/Sophos/Sophos Installer.app/Contents/MacOS/tools/InstallationDeployer
which I saw in an article 120570 relating to Sophos Central.
Nothing seems to work. Should I pre-create the folder it is looking for? Has anyone else encountered this?
Thanks
Mark
