SSH for SUS?
  • June 27, 2012
  • 4 replies
  • 12 views
Is SSH enabled in the SUS appliance by default?
If not, has anyone enabled it? I'm trying to download open ssh but our proxy seems to be getting in the way...
Best answer by bbass
This blog post covers modifying the SUS and enabling SSH:
http://glarizza.posterous.com/jamfs-netsus-appliance-netboot-in-a-box
  • June 27, 2012
  • June 27, 2012
I believe SSH is not installed. You need:
sudo apt-get install openssh-server
  • June 27, 2012
SSH is not installed by default on the appliance. You'll need to do a 'sudo apt-get install openssh-server' to download it. If your FW is in the way, you'll need to work that part out.
  • June 27, 2012
thanks everyone!
