Hi all,
I'm trying to use a script, but it's not showing the correct info in Jamf and I'm not sure where is the issue with it. I thought maybe the "sudo Jamf recon" could trigger the needed info, BUT...sending the command through a Jamf policy compared with the same command running locally from a Mac, the output is totally different - the correct info is showing up in Jamf IF ran from the Mac itself!
Is there something that recommend to do? The whole idea behind this EA is to get a sense of what Mac is missing the "login_date" and label these as "Macs where the users didn't go with the SSO login, therefore we need to <enforce> them via a popup message".
Thanks,
CC
Nevermind...I think I found the issue.
