Standard users wifi settings Monterey
  • June 1, 2022
  • 7 replies
  • 79 views
ejadadic
Greetings everyone,
I would like to see if folks have a solution in place for standard Monterey users being able to modify wifi settings without admin privileges?
geoff_widdowson
I run a policy on all my device that unlocks the network settings.
security authorizationdb write system.preferences.network allow
security authorizationdb write system.services.systemconfiguration.network allow
/usr/libexec/airportd prefs RequireAdminNetworkChange=NO RequireAdminIBSS=NO
ejadadic
  • June 1, 2022
Thanks for the reply. We run something similar at least in the last part
/usr/libexec/airportd prefs RequireAdminNetworkChange=NO RequireAdminIBSS=NO worked in the past, does this require to be run at each reboot?
geoff_widdowson
Each of my unlock polices is set to run each week. I don't think you need to do it every reboot, but something reverts the setting back to default, I forget what. The polices running weekly works for me.
ejadadic
  • June 3, 2022
Thank you!
Hi, what target systems is this going to? I'm trying your exact script, I copied and pasted it... And while it looks unlocked it will still ask the user for admin username and password when they click apply.
I need to be able to give users the power to re-arrange the order and remove unwanted wifi networks.
I decided to run the commands one by one inside terminal and noticed that it barks at that last one. I get the following error "Failed to commit preference changes (Permission denied).".
I saw on some other posts a suggestion to address the network port direct via en0 or whatever address your wifi is on but that sadly made no difference.
KyleEricson
  • June 9, 2022
@ejadadic I would set up Outset to run this script at login-every so it will ensure users don't lose access. I think this database gets reset after updates and sometimes after reboot.
https://github.com/chilcote/outset
