System Image Utility Automator Workflow issues (its doesn't work)
  • January 13, 2012
  • 13 views
I've sent this to support, but thought I'd ask here too..
Trying to build a 10.7 image with 10.7 SIU and the Casper Workflow.
I've run this through a few times and its just not working.
None of the setting that I'm putting in the Configure Casper for Netboot' are being used.
It creates the image as expected and its a netboot image, that part all works, but there is no Casper Imaging App on the volume, auto login and auto start don't work..
Yes, I could spin up an image 'manually' but I'd like this to work as it should.
Any thoughts?
(also, when you save a workflow, it blanks out the settings for casper)
Jak,
I am having a similar issue. I've got a ticket in as well.
  • January 18, 2012
phew! good stuff, thought I was going mad.. I'd really like the automator action to create a slimmed down netboot image, locked down like the old one did.
I can do it all myself of course, but I'd rather it was done for me :)
