Good Morning,
We ran into a rather strange issue with the support folders within the system wide library folder. When we capture using composer, it locates and correctly moves the system wide files/folders into the correct folder. They show up as /Library/Application Support and so on.
However, when I install this package onto either a Snow Leopard or Lion OS base Mac, it takes that files/folders and installs them into the local user library folder instead. Rendering the license files, registration information and so on to be single user type files and therefore, as a new user logs into a system, they have to re-register and so on.
Does anyone else have this experience within Composer? Is there some other method of capturing the snapshot of the base drives for installs like this?
Thank you again for any suggestions and feedback.
Mick
I haven't ran into this issue. What version of Composer are you using?
