TeamViewer Assignment not working reliable
  • March 19, 2021
  • 14 replies
  • 249 views
Hey,
I have a problem with my TeamViewer Installation script.
The download and installation part works great, but the assignment isnt working reliable.
I have followed the steps from here: https://community.teamviewer.com/English/kb/articles/50739-mass-deployment-on-macos
I have added a 'sleep' and increased the '-wait' parameter, both without success.
Sometimes it works, sometimes it does not.
Is there a more reliable way to assign the device in TeamViewer?
Here is my script:
#!/bin/zsh
# Downloads and installs latest TeamViewer Host with custom configuration
# Runs the TeamViewer Assignment Tool after the installation
# Provide configuration details via jamf parameter:#
#   Parameter $4 = Teamviewer configuration ID
#   Parameter $5 = Teamviewer assignment API token
# Created 16. March 2021
# Precheck - configuration id
if [[ -z $4 ]]; then
    echo "$(date): No teamviewer configuration id provided."
    exit 1
    tv_customID="$4"
# Precheck - assignment api token
if [[ -z $5 ]]; then
    echo "$(date): No teamviewer api token provided."
    exit 1
    tv_apiToken="$5"
# Generate url with confiugration id
downloadUrl="https://dl.teamviewer.com/download/version_15x/CustomDesign/Install%20TeamViewerHost-idc$tv_customID.pkg"
# Choices xml for silent installation
choices_xml=$(
    cat <<EOF
<?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<array>
  <dict>
    <key>attributeSetting</key>
    <integer>1</integer>
    <key>choiceAttribute</key>
    <string>selected</string>
    <key>choiceIdentifier</key>
    <string>com.teamviewer.teamviewerSilentInstaller</string>
  </dict>
</array>
</plist>
EOF
# Create working directory
# stolen from here: https://gist.github.com/talkingmoose/a16ca849416ce5ce89316bacd75fc91a
echo "$(date): Creating working directory"
workDirectory=$( /usr/bin/basename $0 )
tempDirectory=$( /usr/bin/mktemp -d "/private/tmp/$workDirectory.XXXXXX" )
downloadFilePath="TeamviewerHost-idc$tv_customID.pkg"
# change directory to temporary working directory
echo "Changing directory to working directory "$tempDirectory""
cd "$tempDirectory"
# Download
echo "$(date): Downloading Teamviewer Host Application"
/usr/bin/curl --location --silent -o "$downloadFilePath" "$downloadUrl"
# Preparation
echo "$(date): Creating choices.xml"
echo "$choices_xml" > "choices.xml"
# Installation
echo "$(date): Installing Teamviewer Host Application"
echo "$(date): .pkg path: $downloadFilePath"
/usr/sbin/installer -pkg "$downloadFilePath" -applyChoiceChangesXML "choices.xml" -target /
sleep 30
# Assignment
echo "$(date): Run Teamviewer assignment"
tv_assignmentHelper="/Applications/TeamViewerHost.app/Contents/Helpers/TeamViewer_Assignment"
tv_hostname="$(hostname -s) | $(id -P $(stat -f%Su /dev/console) | cut -d : -f 8)"
${tv_assignmentHelper} -api-token "$tv_apiToken" -alias "$tv_hostname" -wait 60
# clean up
echo "$(date): Cleanup"
/bin/rm -Rf "$tempDirectory"
Any help is appreciated,
Greetings
Martin
  • March 22, 2021
Hello, I am using this easy script and working fine.
!/bin/bash
cd /tmp
Download and Install custom host
echo "Downloading and Installing custom host"
cd /tmp
curl -L https://download.teamviewer.com/download/version_15x/CustomDesign/Install%20TeamViewerHost-XXXXXXpkg -o /Users/account/Downloads/TeamViewerHost-XXXXX.pkg
Sudo Installer -pkg /Users/account/Downloads/TeamViewerHost-XXXXX.pkg -target /
echo "10 seconds wait"
sleep 10
Assignment
echo "Running the account assignment"
computername=$(hostname -s)
sudo /Applications/TeamViewerHost.app/Contents/Helpers/TeamViewer_Assignment -api-token XXXXXXXX -group "ALL | Macbooky" -grant-easy-access
sleep 10
  • March 22, 2021
Hey,
thanks for the input.
It looks like your script uses the same logic to run the TeamViewer assignment, does this really works 100% of the time?
I have tried some additional things with my script, all without success:
- I have added some logic to wait with the assignment until the TeamViewer host service is running
- I found this doc article which uses a different syntax for the assignment helper:
sudo /Applications/TeamViewerHost.app/Contents/Helpers/TeamViewer_Assignment assign YES -api-token 12345678 -group SomeGroup
note the 'assign YES'
I think i will have to open a ticket with teamviewer support
  • March 23, 2021
Yes, it works everytime
  • April 1, 2021
Update:
I have asked the TeamViewer support about this and it looks like you have to sperate the installation and assignment.
According to TeamViewer there is no known way to combine the installation and assignment in one script.
But i did some digging with composer and found a plist which can be used to determine whether the assignment has run, and to which account the app is assigned.
Here is a Extension attribute which returns the same values you can see under "Account Assignment" in the teamviewer preferences.
RESULT='Not installed'
if [[ -e '/Applications/TeamViewer.app' || -e '/Applications/TeamViewerHost.app' ]]; then
    RESULT='Not assigned'
    AccountName=$(defaults read /Library/Preferences/com.teamviewer.teamviewer.preferences.plist OwningManagerAccountName 2>/dev/null)
    CompanyName=$(defaults read /Library/Preferences/com.teamviewer.teamviewer.preferences.plist OwningManagerCompanyName 2>/dev/null)
    if [[ -n "$AccountName" && -n "$CompanyName" ]]; then
        RESULT="$AccountName,$CompanyName"
/bin/echo "<result>$RESULT</result>"
I think i will use this to find devices without a device assignment to run the assignment policy more efficiently.
macservit
  • May 14, 2021
I realize this is an older thread, not sure if anyone is still watching... I'm having assignment issues using multiple variations of the scripts in this thread. The issues so far are only with Big Sur (this is all I've tested so far). The script runs perfectly when I run it directly on the target machine, but it fails to assign when I run it through my RMM tool. I'm considering trying to run it from Jamf, but want to make sure it's not an OS issue first...
Forum|alt.badge.img+19
  • May 14, 2021
@macservit This worked for me the last time I worked on a TeamViewer assignment project:
api="API-STRING-GOES-HERE"
group="GROUP-YOU-WANT-TO-ASSIGN-TO"
serial=$(system_profiler SPHardwareDataType | awk '/Serial Number/ {print $4}')
assignmentTool="/Applications/TeamViewerHost.app/Contents/Helpers/TeamViewer_Assignment"
count="1"
echo "Pausing for a few seconds..."
sleep 5
# Set up the assignment
echo "Attempting to assign up to 5 times..."
while ! "$assignmentTool" -api-token "$api" -group "$group" -alias "$serial" -grant-easy-access -verbose; do
    echo "Assignment failed."
    (( count++ ))
    if [[ "$count" -ge "5" ]]; then
        echo "Assignment failed 5 times; exiting."
        exit 1
    sleep 5
done
echo "Successfully assigned TeamViewerHost."
Note that this was done immediately after installation so I paused for a few seconds before I proceeded with the assignment.
  • May 15, 2021
@macservit - A little old but everything here is still gold. Believe me, I used this thread and few others to put together the pieces to get this done.
The one call out which I do not believe is called out here is the account assignment and might be the problem. If you look at @ryan.ball post he is running the account assignment up to 5 times until it's complete with a short 5-second pause before it attempts it. The reason for this is the TeamViewer services need to be started and if you try before that it won't work. If you don't have a sleep period long enough(I personally use 60 seconds) or have a retry statement the account assignment will fail. You can read more about some of that here - Teamviewer Account Assignment
I hope this helps you.
macservit
  • May 18, 2021
Thanks @Levi_ and @ryan.ball . I'm really scratching my head with this one, as I have a bunch of endpoints that have had TV Host on them for some time now (months), so clearly the service is running. Or maybe it's not... I'll try to leverage pieces of the script on the page above to check for the service running and go from there.
  • May 19, 2021
Hey @macservit ,
I ended up with this assignment script.
This runs as a second policy after the teamviewer installation.
In addition to this i have created a smart group for the clients where the assignment did not completed yet. (The extension attribute used for this is a few posts up). The assignment script is scoped to this smart group and runs daily.
# Script to run the TeamViewer Assignment Helper
# works for the full client and the host version
# Parameter $4 = reassign ( true | false )
# Parameter $5 = API-Token
# Parameter $6 = TeamViewer Group name
# precheck - reassignment
REASSIGN=false
if [ "$4" == "true" ]; then
    REASSIGN=true
# precheck - api token
    echo "$(date): No teamviewer API Token provided."
    exit 1
    tv_apiToken="$5"
# precheck - group
if [[ -z $6 ]]; then
    echo "$(date): No teamviewer group provided."
    exit 1
    tv_group="$6"
# precheck - installed TeamViewer Version
if [ -f '/Applications/TeamViewerHost.app/Contents/Helpers/TeamViewer_Assignment' ]; then
    echo "$(date): TeamViewer Host installed"
    tv_service="/Applications/TeamViewerHost.app/Contents/MacOS/TeamViewer_Service"
elif [ -f '/Applications/TeamViewer.app/Contents/Helpers/TeamViewer_Assignment' ]; then
    echo "$(date): TeamViewer Full Client installed"
    tv_service="/Applications/TeamViewer.app/Contents/MacOS/TeamViewer_Service"
    tv_assignmentHelper="/Applications/TeamViewer.app/Contents/Helpers/TeamViewer_Assignment"
    echo "$(date): No TeamViewer Assignment helper found. TeamViewer might not be installed"
    exit 1
# teamviewer processes
# get all running teamviewer related processes and count them
processCount=$(pgrep -f "$tv_service" | wc -l)
counter=0
serivceStarted="false"
startTeamViewerService() {
    echo "$(date): Start TeamViewer Service"
   /bin/launchctl load /Library/LaunchDaemons/com.teamviewer.teamviewer_service.plist
   serivceStarted="true"
# timeout after 3 minutes (36x sleep for 5 sec)
while [[ $counter -le 36 ]]; do
    if [[ $processCount -eq 1 ]]; then
        echo "$(date): TeamViewer is running, run assignment"
        if [ "$REASSIGN" == "true" ]; then
            echo "$(date): Run TeamViewer Assignment with reassign parameter"
            ${tv_assignmentHelper} -api-token "$tv_apiToken" -alias "$tv_hostname" -group "$tv_group" -reassign
            break
            echo "$(date): Run TeamViewer Assignment"
            break
        echo "$(date): Waiting for TeamViewer to start"
        if [[ "$serivceStarted" == "false" ]]; then
        sleep 5
        ((counter++))
done
# Created 06. April 2021
REASSIGN=false
    REASSIGN=true
    exit 1
    tv_apiToken="$5"
# precheck - group
    exit 1
    tv_group="$6"
    exit 1
counter=0
            break
            break
        sleep 5
        ((counter++))
done
This has worked for the most clients, but unfortunately not for those clients with a different custom host installed and assigned to a different account. In this case, the existing assignment was removed, but i found no way to assign them to the new account without removing the existing client first and installing the new custom client.
i hope this helps
macservit
  • June 30, 2021
To close the loop on this, I spent a fair amount of time on the phone with TeamViewer support and came up with the script below. Seems to work consistently. FYI, I install this using my RMM tool instead of Jamf, so there might be some extra code that's not relevant to Jamf. Many thanks to all those who posted answers previously...
!/bin/bash
if [ "$usrUninstallFirst" == "true" ]; then
Uninstall TeamViewer first
#Terminates TeamViewer app echo "Stopping TeamViewer" osascript -e 'quit app "TeamViewer*"' launchctl remove com.teamviewer.Helper
#Delete app & configuration files. echo "Removing TeamViewer app & configuration files" rm -R /Applications/TeamViewer rm -f /Library/PrivilegedHelperTools/com.teamviewer.Helper rm -f /Library/Preferences/com.teamviewer rm -f ~/Library/Preferences/com.teamviewer*
Set working directory to /tmp
current_path=$(pwd)
cd /tmp
cp "${current_path}/choices.xml" .
Move choices.xml to /tmp
mv choices.xml /tmp
echo "choices.xml moved to /tmp"
cd /tmp
curl -O https://dl.teamviewer.com/download/version_15x/CustomDesign/Install%20TeamViewerHost-xxxxxxxx.pkg
installer -applyChoiceChangesXML choices.xml -pkg Install%20TeamViewerHost-xxxxxxx.pkg -target /
sleep 20
Start and confirm the app is running
tvStatus=$(pgrep -x TeamViewerHost)
if [[ "$tvStatus" == "" ]]; then user=$(stat -f%Su /dev/console) sudo -u $user open "/Applications/TeamViewer Host.app/Contents/MacOS/TeamViewerHost"
while [[ "$tvStatus" == "" ]]; do sleep 5 tvStatus=$(pgrep -x TeamViewerHost) echo "Waiting for the app to start"
done
Assignment
sudo /Applications/TeamViewerHost.app/Contents/Helpers/TeamViewer_Assignment -api-token xxxxxxxxxxx -group-id $TVGroupID -alias $computername -grant-easy-access
echo "10 second wait"
sleep 10
Get the TeamViewer ID
tvID=$(/usr/libexec/PlistBuddy -c "Print :ClientID" /Library/Preferences/com.teamviewer.teamviewer.preferences.plist)
Get the TeamViewer app type
if [ -d "/Applications/TeamViewerHost.app" ] ; then
appType=Host
appType=Full
Check for assignment
AccountName=$(defaults read /Library/Preferences/com.teamviewer.teamviewer.preferences.plist OwningManagerCompanyName 2>/dev/null)
if [ "$AccountName" == "" ] ; then
Assigned=NONE
Assigned=$AccountName
echo "ID: $tvID - App type: $appType - Assignment: $Assigned"
  • December 14, 2021
This may be a bit of a dead thread but I got the TeamViewer install and assignment working and I'm super happy about it.  I thought I'd share it here for others if they need. It may not be the cleanest or "proper" in all aspects. But it works!
#!/bin/bash #These variables is the ONLY thing to modify in this script idc='' token='' group='' #Uninstall TeamViewer #Terminates TeamViewer app echo "Stopping TeamViewer" osascript -e 'quit app "TeamViewer_Host"' launchctl remove com.teamviewer.Helper #Deletes configuration files. echo "Removing TeamViewer configuration files" rm -f /Library/PrivilegedHelperTools/com.teamviewer.Helper rm -f /Library/Preferences/com.teamviewer* rm -f ~/Library/Preferences/com.teamviewer* #Set working directory to /tmp current_path=$(pwd) cd /tmp sudo cat << EOF > choices.xml <?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" http://www.apple.com/DTDs/PropertyList-1.0.dtd> <plist version="1.0"> <array> <dict> <key>attributeSetting</key> <integer>1</integer> <key>choiceAttribute</key> <string>selected</string> <key>choiceIdentifier</key> <string>com.teamviewer.teamviewerhostSilentInstaller</string> </dict> </array> </plist> EOF cp "${current_path}/choices.xml" #Download and Install custom host echo "Downloading and Installing custom host" cd /tmp sudo curl -O https://dl.teamviewer.com/download/version_15x/CustomDesign/Install%20TeamViewerHost-idc$idc.pkg sudo installer -applyChoiceChangesXML choices.xml -pkg Install%20TeamViewerHost-idc$idc.pkg -target / #This wait is to allow time for the install to finish before running the account assignment echo "10 seconds wait before running the account assignment" sleep 10s #Assignment echo "Running the account assignment" sudo /Applications/TeamViewerHost.app/Contents/Helpers/TeamViewer_Assignment -api-token $token -group "$group" -grant-easy-access -reassign
  • July 5, 2023
Hey @avawdrey ,
does your script still work with the latest OS for you?
it worked once, then stopped working and I can’t figure out why.
  • July 6, 2023
We lost 2 days troubleshooting the assignment part and finally got it to work consistantly:
  • Installation: we use Jamf App Catalog
  • Assignment: we added "wait -45"
The line now looks like:
/Applications/TeamViewer.app/Contents/Helpers/TeamViewer_Assignment -api-token $token -alias $name -reassign -wait 45 -group-id $group_id
The script now looks like this:
#This script will assign Teamviewer to a Teamviewer account.
#Written by Laura DeSchryver laura@yaska.eu
#Last revision 05.07.2023
#Get API token from policy
token=$4
#Get groupID from Teamviewer, you can find it in the URL of your group
group_id=$5
name=$(hostname)
if [[ -e /Applications/TeamViewerHost.app/ ]]; then
/Applications/TeamViewerHost.app/Contents/Helpers/TeamViewer_Assignment -api-token $token -alias $name -reassign -wait 45 -group-id $group_id
if [[ -e /Applications/TeamViewer.app/ ]]; then
It works every single time.
thellum
  • January 4, 2024
token=$4
group_id=$5
name=$(hostname)
@julienvs I note that you have "TeamViewerHost.app" without spaces in the filename, whereas "TeamViewer Host.app" is how it presents in my /Applications. Does the script function with this loss of the <space> in the filename?
