Temporary User Promotion - Doesn't work when using Okta as IdP
  • Aug 10, 2024 5:55 AM UTC
  • 94 views
While testing the Temporary User Promotion feature I noticed that nothing happens when clicking the option in the menu bar. I have various attributes set as far as UserPromotionRole, UserPromotionReason, UserPromotionChoices. Any thoughts?
Running on JC 2.37.0.
com.jamf.connect plist
<dict>
<key>Appearance</key>
<dict>
<key>MenubarIcon</key>
<string>********************</string>
<key>MenubarIconDark</key>
<string>*******************</string>
<key>ShowWelcomeWindow</key>
<false/>
</dict>
<key>CustomMenuItems</key>
<dict>
<key>getsoftware</key>
<string>Self Service</string>
</dict>
<key>HiddenMenuItems</key>
<array>
<string>preferences</string>
<string>quit</string>
</array>
<key>IdPSettings</key>
<dict>
<key>OktaAuthServer</key>
<string>***************</string>
<key>Provider</key>
<string>Okta</string>
</dict>
<key>TemporaryUserPermissions</key>
<dict>
<key>TemporaryUserPromotion</key>
<true/>
<key>UserPromotionDuration</key>
<integer>360</integer>
<key>UserPromotionLimit</key>
<integer>10</integer>
<key>UserPromotionReason</key>
<true/>
<key>UserPromotionChoices</key>
<array>
<string>"General Use"</string>
<string>"I want it"</string>
<string>"Approved"</string>
</array>
<key>UserPromotionRole</key>
<array>
<dict>
<key>Duration</key>
<key>Name</key>
<string>**************</string>
</dict>
</array>
<key>UserPromotionTimer</key>
<true/>
<key>VerifyUserPromotion</key>
<true/>
</dict>
<key>PasswordPolicies</key>
<dict>
<key>CheckOnNetworkChange</key>
<true/>
<key>ExpirationCountdownStartDay</key>
<integer>**</integer>
<key>ExpirationNotificationStartDay</key>
<key>NetworkCheck</key>
<key>PolicyRequirements</key>
<dict/>
<key>SyncPasswordsMessage</key>
<string>Your macOS password is not the same as your OKTA Password, please sync them.</string>
</dict>
<key>SignIn</key>
<dict>
<key>AutoAuthenticate</key>
<true/>
<key>AutoOpenAppAtLogin</key>
<true/>
</dict>
<key>UserHelp</key>
<dict>
<key>HelpOptions</key>
<key>HelpType</key>
<string>URL</string>
</dict>
<key>WebBrowser</key>
<dict>
<key>BrowserSelection</key>
<string>Google Chrome</string>
<key>LaunchBrowser</key>
<true/>
</dict>
</dict>
</plist>
  • Aug 10, 2024 5:57 AM UTC
<dict> <key>Appearance</key> <dict> <key>MenubarIcon</key> <string>********************</string> <key>MenubarIconDark</key> <string>*******************</string> <key>ShowWelcomeWindow</key> <false/> </dict> <key>CustomMenuItems</key> <dict> <key>getsoftware</key> <string>Self Service</string> </dict> <key>HiddenMenuItems</key> <array> <string>preferences</string> <string>quit</string> </array> <key>IdPSettings</key> <dict> <key>OktaAuthServer</key> <string>***************</string> <key>Provider</key> <string>Okta</string> </dict> <key>TemporaryUserPermissions</key> <dict> <key>TemporaryUserPromotion</key> <true/> <key>UserPromotionDuration</key> <integer>360</integer> <key>UserPromotionLimit</key> <integer>10</integer> <key>UserPromotionReason</key> <true/> <key>UserPromotionChoices</key> <array> <string>"General Use"</string> <string>"I want it"</string> <string>"Approved"</string> </array> <key>UserPromotionRole</key> <array> <dict> <key>Duration</key> <integer>360</integer> <key>Name</key> <string>**************</string> </dict> </array> <key>UserPromotionTimer</key> <true/> <key>VerifyUserPromotion</key> <true/> </dict> <key>PasswordPolicies</key> <dict> <key>CheckOnNetworkChange</key> <true/> <key>ExpirationCountdownStartDay</key> <integer>**</integer> <key>ExpirationNotificationStartDay</key> <integer>**</integer> <key>NetworkCheck</key> <integer>**</integer> <key>PolicyRequirements</key> <dict/> <key>SyncPasswordsMessage</key> <string>Your macOS password is not the same as your OKTA Password, please sync them.</string> </dict> <key>SignIn</key> <dict> <key>AutoAuthenticate</key> <true/> <key>AutoOpenAppAtLogin</key> <true/> </dict> <key>UserHelp</key> <dict> <key>HelpOptions</key> <string>***************</string> <key>HelpType</key> <string>URL</string> </dict> <key>WebBrowser</key> <dict> <key>BrowserSelection</key> <string>Google Chrome</string> <key>LaunchBrowser</key> <true/> </dict> </dict> </plist>
  • Sep 10, 2024 4:41 PM UTC
Any luck with this? I am facing the same issue at the moment.
