If you are still using the legacy DEP Portal, I would highly suggest moving to ASM or ABM as it will be required here shortly. Within ASM or ABM, you can create multiple MDM Servers and assign devices for automated enrollment via the same portal. VPP is also handled nicely within ASM/ABM.
I am using ASM so that should not be any problems. Just curious how others have done with this. Since I have not had 2 mdm servers before, there should be some certificates that needs to be issued, how about that? Does it break something with my existing MDM "in production" server?
Nothing will break in your production server. Follow the steps here. You'll then be able to assign devices to that new MDM server.
Do not share the same VPP tokens between the production and test servers. This will temporarily break the token on the production server and you will receive an error that another MDM server may be using your tokens. I think the same might happen with DEP tokens as well.
For that reason we have created new Content Manager accounts (for VPP tokens) in ASM for the test server, and new Site Manager accounts (for DEP tokens), specifically for the test server so they won't interfere with the production server.
