There was a problem communicating with a push server
  • August 21, 2020
  • 36 replies
  • 205 views
Hi there,
we're seeing this as result to all commands (i.e. "Renew MDM profile") issued to all of our iPhones. Since they're currently in different locations all over the world a firewall issue is veeery unlikely.
We're on 10.23.0-t1595614145, Push Notification Certificate is renewed (though still Binary?)
Any help is appreciated.
Tino
  • August 21, 2020
same here
Connection Settings Establish a connection to the Apple Push Notification service.
Protocol Apple will no longer support the binary APNs protocol. For more information, see the Supporting Apple Push Notification Service Over HTTP/2 Knowledge Base article.
Binary
edit: it works at least in one environment now. seems to be very slow everything in the moment
  • August 21, 2020
Same Problem here. I talked with Jamf Support moment ago. there is a problem with communicating between APNS and Jamf Cloud instances in EU Region.
Edit: the answer I got via mail: It looks like we do have an ongoing issues with APN's only on cloud instances not for on-prem.
  • August 21, 2020
Same here. (In South Africa)
  • August 21, 2020
We were experiencing issues enrolling devices through DEP, manual enrolments and config profiles not deploying too so issues with APN's makes sense. We're in the EU region. I've successfully enrolled one Mac now so hopefully it's getting fixed now.
  • August 21, 2020
UK also, very slow, but some commands are getting through
  • August 21, 2020
We're having the same issue - none of our devices are updating in the inventory... reset iPads aren't getting their Pre Enrollment either
  • August 22, 2020
Still having the same issue (UK) here too.
Edit: Saturday 22/8 9:00 GMT - We're getting traffic now, config profiles are getting pushed OK.
  • August 23, 2020
Is anyone else seeing this with manual enrolments at the moment? We can install the CA certificate, then install the MDM profile and then nothing happens after that. No configuration profiles, no Jamf binary and no self service app.
  • August 24, 2020
@RobertPetrie we see exactly the same behaviour.
edit: working now for us
  • August 24, 2020
still experiencing issues with profiles not being pushed...
At least in Austria it seems to be stuck since Friday last week.
New DEP installed devices do not get most of the profiles we push.
Edit: we are on On-Prem v10.23 and use already the HTTP/2 (443) setting for connection. When testing I get an error.
  • August 24, 2020
eu-central-1 APNS
New incident: Investigating
We are observing higher APNS traffic volumes and intermittent failures for customers located in eu-central-1. We are investigating the issue.
https://status.jamf.com/incidents/2mdstr7s0px0
  • August 24, 2020
Same here aswell, been happening for the past couple of days. What is going on and better, what can we do to let it function normal again. We cannot work around this
Same problem here (USA - Florida)
  • August 24, 2020
Same problem for me, East US
  • August 24, 2020
Same problem here in Texas. We noticed a syncing issue last week and it is ongoing. We are on-prem.
atabique
  • August 24, 2020
Same here...in California
  • August 25, 2020
I don't know if it's related, but I am trying to renew the ABM server token for our on-prem JSS and if I try to upload it says "the file received was not valid". The Automated Device Enrollment page in JSS says "Information out of date. Awaiting next sync"
Test with TwoCanoes "Push Disgnostic" seems fine (APNs tests completed with 63 passed and 0 failed)
sdagley
  • August 25, 2020
@carlo.anselmi (and everyone else posting on this issue) What version of the JSS are you running?
  • August 25, 2020
@sdagley sorry forgot to mention it's JSS 10.17.1-t1574185757 on prem
  • August 25, 2020
Hello, having this same issue in US East
Running 10.23.0-t1595614145, and we just renewed our Push Notification Certificate earlier this summer
sdagley
  • August 25, 2020
Since this issue is being reported across multiple versions, and impacts both on-prem and AWS/Jamf Cloud hosted instances, it'd seem like this is an Apple issue. Not that https://developer.apple.com/system-status/ has any indication things aren't working.
  • August 26, 2020
Hello from Austria :)
still experiencing the issue here.
We use on-prem JSS 10.23.0-t1595614145
ThijsX
Forum|alt.badge.img+20
  • Employee
  • August 26, 2020
Just checking in; anyone else experiencing profiles being installed due ADE/PreStage enrollment are looping and taking ages?
  • August 26, 2020
@txhaflaire yes we have the same issue...what we already found out is that when you "cancel all" pending and failed commands the loop is solved and device continues to "time zone" selection.
Surajit
  • August 26, 2020
@txhaflaire & @patrick030 Yes, we are facing the same issue. DEP enrollments are stuck on a loop, in our case directory binding is failing & after almost 10 minutes, the Computer hangs. We did a force reboot & again it gets in the same loop. When I check the computer record on Jamf, I see an Unmanaged entry & multiple failed commands for Directory Binding. Informed Jamf Support, waiting for their reply.
