I am trying to jamfify three things that I always do for the computers in my school manually:
- Tap to Click
- Unnatural Scrolling
- Enable Dragging (without lock)
The first one I have found a semi-solution for but it seems buggy. The second I found a command line option but doesn't seem to work, and I have had no luck finding any option at all for the third.
First, the second one: Unnatural Scrolling. The following command is supposed to work but I have not found it to change the scrolling direction:
- defaults write NSGlobalDomain com.apple.swipescrolldirection -bool false
Second, the first: Tap to Click: the following four commands almost work:
- defaults write com.apple.AppleMultitouchTrackpad Clicking -bool true
- defaults write com.apple.driver.AppleBluetoothMultitouch.trackpad Clicking -bool true
- defaults -currentHost write NSGlobalDomain com.apple.mouse.tapBehavior -int 1
- defaults write NSGlobalDomain com.apple.mouse.tapBehavior -int 1
But even though the checkbox is checked to allow tap to click, it doesn't actually work until you manually uncheck it and recheck it again.
Thirdly, the third one: Enable Dragging. This is done manually within the Accessibility widget, and it is kind of buried. Any ideas on this one?
