Hello - I know this topic has had lots of discussion, but I'm having trouble and hopefully the forum can help!
We cant use NetBoot so we are stuck using a bootable USB drive to start Casper Imaging. I made one a while back by installing Snow Leopard directly onto a USB flash drive along with Casper Imaging and then I used Composer to capture a DMG from the USB disk. This worked great - users could download the DMG file and use Disk Utility to restore the DMG to thier own USB stick.
Now - for some reason - I cant restore my DMG file to USB stick. Even the old one ! Disk Utility restores the image onto the USB stick, and I can start to boot with it but after about a minute the Apple symbol on the bootup screen changes to a "buster" symbol and its all over.
I get this over and over now, all different USB disk types and multiple versions of DMG files. I can't help but think I'm doing something wrong...
Any advice? Thanks !
