Trying to find the best way to rename computers after enrollment
  • September 16, 2021
  • 44 replies
  • 308 views
I'm currently testing Jamf and have everything working as I want with with the exception of figuring out the best way to rename computers after they are setup.
Currently I'm using Jamf with Jumpcloud pushing the user accounts for staff to an employee's computer however I'm stuck with the default computer name of Macbook Pro. I'm trying to figure out the best way to script this or use a policy that runs after the user is setup  to that a machine can be renamed for username-Macbook Pro.
I'm wondering what the best way is to accomplish the renaming task so it can be automated and not have to be done manually each time a computer is deployed .
Thanks for any suggestions.
Best answer by ryan_ball
Is there a way to combine these all into one script that can run automatically after enrollment? Or does each step need to be done manually?
@mm2270 basically gave the entire answer. His code in a script would be:
#!/bin/bash # Get the logged in username logged_in_user=$( echo "show State:/Users/ConsoleUser" | /usr/sbin/scutil | /usr/bin/awk '/Name 😕😕 && ! /loginwindow/ { print $3 }' ) # Create a string comp_name="${logged_in_user}-MacBook Pro" # Rename the Mac using the jamf command line tool /usr/local/bin/jamf SetComputername -name "$comp_name" exit 0
Just take that, create a file named rename.sh using a Text Editor like Visual Studio Code, then upload that to your Jamf Pro and create a policy leveraging that script that runs once at check-in most likely as you want the user to actually be logged in when it runs.
I think ideally I need to run the command "jamf SetComputername -name" but I'm not sure how to have it automatically pull the username and then add MacbookPro to it so then the computer name ends up being bsmith-Macbook Pro
If all you need is the name of the logged in user account, use something like this in a script.
logged_in_user=$(/usr/sbin/scutil <<< "show State:/Users/ConsoleUser" | awk '/Name 😕😕 && ! /loginwindow/ {print $3}')
Then you can combine that variable of logged_in_user with the rest of the computer name to make it into a complete name, like
Finally, use that for naming the machine
# Name Your Computer.sh
#The user will choose their department from a drop down menu
#dept=$(/usr/bin/osascript << EOD
#tell application "System Events"
#activate
#set Department to (choose from list {"K", "1st", "2nd", "3rd", "4th","5th", "6th"} with title "Departments" with prompt "Please choose your department")
#end tell
#EOD
#The user will choose their building from a drop down menu
#bldg=$(/usr/bin/osascript << EOD
#activate
#set Building to (choose from list {"HS", "MS", "IC", "PC"} with title "Buildings" with prompt "Please choose the building you work at")
#end tell
#EOD
#The user will input the value of their asset tag
tag=$(/usr/bin/osascript << EOD
activate
set AssetTag to text returned of (display dialog "Please enter your LastName followed by FirstInitial (ex.SpacklerC)" default answer "" buttons {"Continue"} default button 1)
end tell
EOD
#This takes the data collected from the user and sets it as the Computer Name and submits the name to the Jamf API
deviceName="DO-$tag"
#set all the name in all the places
/usr/local/bin/jamf setComputerName -name "$deviceName"
/usr/local/bin/jamf recon
This is the script I use at the School District I manage. You can tweak the script however you'd like. If you have any questions let me know.
Yes of course. I was only adding in lines above to show how it can be done. But if you put them into a shell script in the above order, that should get you most of the way there. Something like
#!/bin/zsh logged_in_user=$(/usr/sbin/scutil <<< "show State:/Users/ConsoleUser" | awk '/Name 😕😕 && ! /loginwindow/ {print $3}') comp_name="${logged_in_user}-MacBook Pro" /usr/local/bin/jamf SetComputername -name "$comp_name"
 This is quite simplified, as there's a lot of checks and other things such a script could include. But I'm purposely keeping it simple here for you so it makes sense.
Forum|alt.badge.img+19
Thanks for simplifying it. Testing it now via a policy.
I received this error in the logs. My script is below and I've attached it to a policy in Jamf.  What am I missing?
# Create a string
# Create a string
# Create a string
# Create a string
Did you use TextEdit to create the sh file or a text editor like Visual Studio Code or Sublime Text? TextExit would have to be set in plain text mode and turning off text replacement and things like that. I suggest you use a real text editor used for creating code.
It also appears you also have the Maintenance > Reset Computer Names option added in the policy which will attempt to rename the local Mac to match the name of the Jamf Pro record. You'd want to turn this off.
# Create a string
# Create a string
Well that's weird. There's an error in the awk syntax. There's a backslash "\\" where there should be a forward slash "/"I have no idea how it made it into my post like that, since I just copied and pasted that from a working script.
So anyway, change the "logged_in_user" line to look like this
logged_in_user=$(/usr/sbin/scutil <<< "show State:/Users/ConsoleUser" | /usr/bin/awk '/Name 😕😕 && ! /loginwindow/ {print $3}')
That should fix it.
That should fix it.
Ack!!! It's doing it again. Ok, so its this dang new forum format doing it. Ugh!! Jamf, please fix this. Your forum software is converting some forward slashes to backslashes. What the heck!? Why would it being doing that?
@MBlank Please make sure that the only \\ in the above shown is a / instead.
Forum|alt.badge.img+21
There are plenty of good ways to set the computer name via script on macOS.  I would like to point out however that using any personally identifiable information in the device name is a potential safety and security risk, especially if you are setting the device name for minor students.  Since a device name is broadcast in the clear on any network, you run the risk of allowing a bad actor to know if an individual is in a particular location.
The following can be used to give a Mac a unique name by executing a command via the Files and Processes payload in a policy:
/usr/local/bin/jamf setComputerName -name "Mac-$(ifconfig en0 | awk '/ether/{print $2}' | tr -d :’)”;/usr/local/bin/jamf recon
Just my $0.02
It worked as a local script on the machine and now I'm testing it via a policy in Jamf. Should I leave update inventory checked on Maintainence?
If you change the name of the device, you’ll want to update inventory so that the device record name matches.
At the end of the script you can put
Which will automatically check into jamf after the other parts of the script were run.
Like so:
Forum|alt.badge.img+15
  • September 23, 2021
I was tinkering around a bit thinking about this script, this is what I came up with:
#!/bin/bash # Set variables # Get the last logged in user lastLoggedInUser=`defaults read /Library/Preferences/com.apple.loginwindow lastUserName` # Get Model Name of computer modelName=`system_profiler SPHardwareDataType | grep "Model Identifier" | awk '{print $3}' | sed 's/[0-9]*//g' | tr -d ','` # Get original name of computer oldComputerName=`scutil --get ComputerName` # Generate new computer name computerName=$lastLoggedInUser-$modelName # Set new computer name locally scutil --set ComputerName $computerName scutil --set HostName $computerName scutil --set LocalHostName $computerName # Set the computer name in Jamf to reflect what is set locally on the computer /usr/local/bin/jamf setComputerName -name $computerName /usr/local/bin/jamf recon echo "Computer name has been changed from $oldcomputername to $computerName" exit 0
This script works well for adult users, but due to the PII in the device name, should not be used for K12 student devices. One could make the argument against PII in any device name, but for minors there is a safety and security risk.
Just my $0.02
Just my $0.02
Totally agree! PII is a big issue! I’ve always used an inventory asset number as my computer names or a location based naming scheme (Bldg-Room-Station). That seemed to work out well.
  • October 22, 2021
Are there any variables that can pull the first part of NAME from when the computer is configured instead of the username that {logged_in_user} generates? So the script pulls "Bob" from Bob Smith?
  • October 23, 2021
You can get the last logged in user using:
Then you can get the first name by
fname=`dscl . -read /Users/$lastLoggedInUser RealName | grep ^\\ | awk '{print $1}'`
Then echo that to make sure
echo $fname
  • October 23, 2021
echo $fname
Thanks! Would I be able to use this to rename a computer using the first name instead of the logged in user name by modifying my existing script? This runs right after pre-stage. Or would it not be possible since the user was just created ie during initial setup. Thanks for any additional suggestions.
XXXX=Internal Naming Scheme
#get computer serial number
serialNumber=`system_profiler SPHardwareDataType | awk '/Serial/ {print $4}'`
# Create a string
comp_name="XXXX-MBP-${logged_in_user}-$serialNumber"
jamf recon
  • October 23, 2021
# Create a string
jamf recon
Yes, if you get your first name variable, you will just plug that into where you are setting the computer name variable
  • October 23, 2021
Any chance you can check my handy work and let me know's missing? Scripting is absolutely not my strength 😞
I dropped the serial field so ideally the script should rename the computer right after prestage to XXXX-MBP-Firstname
logged_in_user=$lastLoggedInUser=`defaults read /Library/Preferences/com.apple.loginwindow lastUserName` 😕😕 && ! /loginwindow/ {print $3}')
$fname=`dscl . -read /Users/$lastLoggedInUser RealName | grep ^\\ | awk '{print $1}'`
echo $fname
# Create a string
comp_name="XXXX-MBP-${$fname}-$”
jamf recon
  • October 23, 2021
echo $fname
# Create a string
jamf recon
Huge thanks for any more help you can provide : 😀
