Unable to mount network shares 10.9.1
  • February 14, 2014
  • 24 views
Our network shares are failing to mount on some of our machines. To try and fix this I created a configuration profile with the following payloads: Login items, under Network mounts I put the path to the users network share and another payload for the Dock so the share will appear there too with the path as well. Now when the configuration profile tries to apply to my test machine i get an error message stating "Unable to decrypt encrypted profile." Has anyone experienced the same issue?
  • February 14, 2014
Can you manually mount the network shares? Do you have FileVault enabled?
  • February 14, 2014
Yes i am able to mount them manually. No I do not have FileVault enabled.
  • Employee
  • February 16, 2014
Sounds like either current or old mcx settings in the JSS are over-riding or interfering with mcx settings of most likely an OD... or visa versa.
