Unable to rename laptop (Macbook Air) using a script on Policy on Jamf Pro
  • May 4, 2022 3:02 PM UTC
  • 28 replies
  • 425 views
Show first post
howie_isaacks
  • May 5, 2022 1:49 PM UTC
Honestly haven't seen that issue myself but like I said it is a separate policy that runs during enrollment.
It doesn't do any harm for me to run the policy again. I'm sure I will figure it out. It doesn't happen often enough to light a fire under me to get it solved.
TonyNelson
  • Aug 28, 2025 2:16 PM UTC
when I run “jamf setComputerName -fromFile”
I get an error “You must specify a computer name.  Use the -name flag.”  The csv file contains the serial number followed by the computername.  shouldn’t this work?
sharriston
  • Aug 29, 2025 7:51 PM UTC
I have a one liner you can use in Files and Processes>Execute Command. It’s what we use for our generic enrollment name:
/usr/local/jamf/bin/jamf setComputerName -target / -useSerialNumber -prefix "M1-"
