The policy log looks like this:
Script result: no DART to remove
Exiting Cisco AnyConnect Secure Mobility Client
Uninstalling Cisco AnyConnect Network Visibility Module...
Successfully removed Cisco AnyConnect Network Visibility Module from the system.
Uninstalling Cisco AnyConnect Secure Mobility Client...
Executing: /usr/bin/kmutil showloaded
No variant specified, falling back to release
Successfully removed Cisco AnyConnect Secure Mobility Client from the system.So it looks like /usr/bin/kmutil us being called upon for some reason, but if the Cisco uninstall script is running as root, why is that superuser privilege not extended to commands spun off from it? Or is it?
            JamfNation was slow to post my first comment, so I posted it again, then the first one showed up.  Ignore this comment.
            Currently, there is no way around not having to input your credentials on Big Sur and Mojave.
Apple did add the ability to allow the removal of system extensions without a prompt but that is only with Monterey:
SystemExtensions.RemovableSystemExtensions | Apple Developer Documentation
I have not done it with Cisco AnyConnect but I have done it with Cisco AMP using info from here:
Cisco Secure Endpoint Mac Connector Advisory: System Extensions, MDM, and Orbital - Cisco
But the process should be the same with AnyConnect:
Cisco AnyConnect Secure Mobility Client Administrator Guide, Release 4.9 - Appendix: AnyConnect Changes Related to macOS 11 (And Later) [Cisco AnyConnect Secure Mobility Client] - Cisco
"During AnyConnect uinstallation, the user is prompted for administrator credentials to approve the system extension deactivation. On macOS 12 and later, the AnyConnect system extension can be silently removed after deploying a management profile with the addition of SystemExtensions payload to the RemovableSystemsExtensions property. This property must contain the bundle identifier of the AnyConnect system extension (com.cisco.anyconnect.macos.acsockext)."
What you would need to do in JAMF:
- Created a new Configuration Profile
- Configure a new System Extensions payload
- System Extension Types: Removable System Extensions
- Team Identifier: DE8Y96K9QP
- Add Removable System Extensions: com.cisco.anyconnect.macos.acsockext
You, of course, need to make sure the profile has been pushed down before running the uninstall.
I know this isn't of any help for your computers on older OS but you could push them to the newest OS and then do it.
You could try a manual remove with the info here:
Cisco Anyconnect Manual uninstall Mac OS - Community Contributions - Hermes (mit.edu)
            I apologize fore reviving an old thread, but would there be any negatives to letting this removal profile exist on the machines rather than trying to time the config profile to come down before the uninstall script?
            @ImAMacGuy No, there are no negatives. The profile allows a script or user with admin rights to remove the extension. An ordinary user does not get any extra permission from the profile so they still can't remove the Cisco software outside of a Self Service policy.
            Thanks for the script! Works well and no longer requires user interaction in Sonoma!
This worked for me as well!!
Thank you!!
Should note that adding the removable system extension option to the same config profile that allows silent install does not work.
Removable system extension needs to be in its own separate profile.
