Updating to macOS 11.6 with Jamf Pro 10.32.x and MDM commands
  • Sep 17, 2021 7:24 PM UTC
  • 36 replies
  • 634 views
Show first post
  • Dec 14, 2021 5:58 PM UTC
My Jamf rep just said the solution was in this post...but I am not seeing any solution to upgrading a mac to Monterey yet. Has anyone gotten a good workflow to have a standard user (like a student) be able to launch the update from Self Service? The Mass Action stuff is absolutely useless. In what world can someone just send a mass action command to update and then have end user laptops suddenly blast into an update in the middle of a class or worse, a community wide zoom session that we are broadcasting etc....?
  • Dec 14, 2021 6:10 PM UTC
I am guessing that how it does work is described many times over in this post is what they are referring to as a solution.. Mass Action is the only way that did not require the local user to be an admin, and now on M1 devices that still requires local admin. That said Mass Action is not for major OS releases (at least my understanding) . Policy seems to work (just kind of inconsistent on its messaging) but again requires a local admin account. I find Jamf support to be pretty good on somethings, but on OS updates specifically the message just seems to be  "it is, what it is".
  • Dec 14, 2021 6:12 PM UTC
Ive been trying to do the Mass Action for years, every-time i call support on it they say to use a policy, which works sometimes, but still needs to be initiated while a user is logged in (or i missed a step), so not a great solution for a Lab.
funny part (or not)  is when I called about policy they sent me a link on mass action
AJPinto
  • Dec 14, 2021 6:15 PM UTC
Ha, there is no solution in this post. I think you got a runaround. This thread really has nothing to do with OS upgrades. Its all about JAMFs miserable support of OS updates.
Once you get the install macOS monterey.app on to a Mac kicking off the upgrade is a simple matter of running a policy. With a policy you can set all kinds of limitations.
The nuts and bolts of the upgrade script would just be
"/Applications/Install macOS {version here}/Contents/Resources/startosinstall" --agreetolicense --nointeraction --forcequitapps
Getting the install macOS {version} to the Mac is another story. You can use VPP and tell the appstore app to force install, or you can use a terminal command which should fetch the most recent version of macOS.
softwareupdate --fetch-full-installer
Or do what I do since I am a control freak. download Monterey, package it with composer as a .dmg. Deploy it as a policy (caching the dmg) and run a script like this to move it to applications. I took out all the Parameter and Variables so its easier to follow along. I run this in the background weeks before actually upgrading devices. If the installer is in place 1st upgrading is literally just a matter of running a script from a policy.
#!/usr/bin/env bash ## Mount DMG file with no browse to hide the desktop icon echo "...Mounting /Volumes/Install_macOS_Monterey_12.1" sudo hdiutil attach "/Library/Application Support/JAMF/Waiting Room/Install_macOS_Monterey_12.1.dmg" -nobrowse ## Install PKG echo "Copying MacOS Installer to /Applications" sudo cp -R "/Volumes/Install_macOS_Monterey_12.1/Applications/Install macOS Monterey.app" "/Applications/Install macOS Monterey.app" ## Wait 20 seconds to allow for package to transfer sleep 20 ## Unmount DMG echo "Unmounting /Volumes/Install_macOS_Monterey_12.1" sudo hdiutil unmount "/Volumes/Install_macOS_Monterey_12.1" ## Wait 20 sec to make sure DMG unmounts sleep 20 ## Delete DMG sudo rm -rfv "/Volumes/Install_macOS_Monterey_12.1"
  • Dec 14, 2021 6:21 PM UTC
I think the problem here is that the upgrade policy method does not work on Apple Silicon machines.  Mass action or individual computer MDM commands are the only option that seem to work from my experience and research.
AJPinto
  • Dec 14, 2021 6:23 PM UTC
I have not tried this on AppleSilicon yet, I was thinking about that just a moment ago. I think MDM command is the only way to do it and JAMF has absolutely horrible support for MDM commands involving software updates.
  • Dec 14, 2021 6:43 PM UTC
That's an interesting way to get the installer. I managed to package it up and deploy it directly into /Applications. Is there a reason you don't do it that way? The part I am hung up on is creating a policy that will actually kick off the installer for the standard user. If I log into an admin account with secure token enabled and supply the password, it works, but that isn't something I can do on student laptops. This is the most frustrating experience yet in all of my jamf/apple time.
  • Dec 14, 2021 6:46 PM UTC
I haven't attempted this on Intel yet. The M1s in my deployment are the smallest number and right now I've got almost every other device on some level of Catalina right now--that was a big win for us. So My first concern was now getting M1s up to Monterey while thinking that once I crack that code, the Intels will be easier. And Mass Action is just out the window. I can't send an action and have computers randomly starting to update in the middle of class or an exam or get interrupted because they woke up and packed their laptop up to get to school.
  • Feb 7, 2022 4:31 PM UTC
Not sure if you're still having issues with this but here's an incredibly valuable thread with ongoing chatter.
https://community.jamf.com/t5/jamf-pro/macos-installer-script-not-working-for-apple-silicon-m1-macbook/m-p/251358/page/2
tdenton
  • Aug 23, 2022 7:19 PM UTC
@clarkep
We had some great success with the below. Currently using it do a site wide Monterey upgrade in our Labs. With a mix of M1 & Intel Mac's.
https://github.com/grahampugh/erase-install.
Works a treat on Intel devices.
M1 devices require user password and need to be a volume owner. There is'nt away around this to my knowledge due to increase in security on M1 devices.
  • Sep 23, 2022 3:57 PM UTC
@clarkep
I will second this method. I am. also combing it with Nudge-Swift so Nudge will alert users to upgrade their machines and then when they click the install button it opens the erase install policy from Self Service. Since quite a few of my users are standard users we'll probably make it just a standard policy to do the full install as an "update" with Nudge and erase install.
