I have a series of issues I'm running into in my upgrade testing from JSS 8.62 to JSS 9.0. I'll post each issue separately for sanitys' sake. FOr this series of issues: an "upgrade" is actually installing JSS 9 on a test server, restoring a 8.62 DB, then launching the WebApp to upgrade tables. I did not do an inplace upgrade since we are going to migrate server platforms and start from v9.0 on the new server.
Issue 4 - disabled policies are re-enabled after upgrade. This one concerns me - a lot. It's not all policies, but I've noticed two so far. Both are disabled in the 8.62 production environment but were re-enabled after the upgrade to 9.0. The policy that is re-enabled after having previously been disabled expired on "Expires On: 6 /15 /2011 at 7:00 pm " It is still set to have expired on "15 / 06 / 2011 at 7:00 pm", but shows as active. If added to the dashboard, it says that 0 computers remain to run the policy. The policy luckily has no targets, so it didn't affect any clients, but if it was one that is ongoing or something like that... So is the policy active or not? If I check the Policies in Scope for a client, it does have the policy name.
As an aside is there any way to change the date format for JSS v9.0? Us lazy Americans like our Month/Day/Year format :)
