Hey, we are just upgrading an on-prem Jamf Pro instance from version 10.7.1 to newest Version. We follow: https://www.jamf.com/jamf-nation/articles/647/incremental-upgrade-scenarios-for-jamf-pro-10-0-0-or-later
After Upgrading Java to version 11 and MySQL 8, we installing version 10.14.0. Now we get the following errors in JamfProServerLog:
[ERROR] [duledPool-4] [UpdateMDMCommandQueue ] - Error selecting devices - java.lang.NullPointerException
at com.jamfsoftware.jss.objects.mobiledevicemanagement.UserPushToken.isTokenMdmCapable(UserPushToken.java:313)
at com.jamfsoftware.jss.objects.mobiledevicemanagement.UserPushToken.isMDMCapable(UserPushToken.java:307)
at com.jamfsoftware.jss.objects.mobiledevicemanagement.UpdateMDMCommandQueue.updateQueue(UpdateMDMCommandQueue.java:296)
at com.jamfsoftware.jss.objects.mobiledevicemanagement.MDMCommandQueueMonitor$MonitorRunnable.run(MDMCommandQueueMonitor.java:73)
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
at java.base/java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305)
at com.jamfsoftware.jss.core.threading.JssFutureTask.run(JssFutureTask.java:41)
at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.base/java.lang.Thread.run(Thread.java:834)
and....
[ERROR] [eralPool-40] [APNSFeedbackConnection ] - IOException getting and entering feedback data: java.net.SocketException: Socket input is already shutdown at java.base/sun.security.ssl.SSLSocketImpl.getInputStream(SSLSocketImpl.java:795) at com.jamfsoftware.jss.pushnotification.connection.APNSFeedbackConnection.getFeedbackData(APNSFeedbackConnection.java:34) at com.jamfsoftware.jss.pushnotification.connection.APNSFeedbackConnection.run(APNSFeedbackConnection.java:88) at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264) at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128) at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) at java.base/java.lang.Thread.run(Thread.java:834)
Can somebody help us?
