Anyone else lose their clustering config when upgrading to v.9.11?
Upgrade to 9.11 broke clustering
Best answer by easyedc
got this note from Support.
If we go into the Database.xml on the DMZ server, is it pointed to the right database? We should be able to find it in: /usr/local/jss/tomcat/webapps/ROOT/WEB-INF/xml Sometimes those settings get cleared out during an upgrade. Let us know if this is configured properly (if it is, let's try restarting Tomcat on that server) and we can dig a little deeper if this doesn't fix the issue.
Pointed to the internal server's IP and restarted tomcat. Fixed it.
