Upgrading from JAMF NetBoot/SUS 3 to 4
  • February 22, 2016
  • 4 replies
  • 31 views
dlondon
Hi All,
Haven't seen anything in the documentation or the forum on how to do an upgrade from version 3 to 4 of the NetBoot/SUS. We have it on Redhat Server.
Has anyone done it? Is it just a matter of running the script or are there some things to do before hand?
Regards,
David
Best answer by TimT11
SSH into the server and type
download file -e.g wget http://content.jamfcloud.com/NetSUSLP_4.0.0.run
then type
install sudo sh NetSUSLP_4.0.0.run
This will update the current config.
Cheers
  • February 22, 2016
then type
Cheers
  • February 22, 2016
Yeah, what @TimC said is accurate.
Running the .run file overtop will update everything accordingly. Quite nice, actually.
Regards,
TJ
I stopped services before i ran it as a precaution but looking at reviews above, no need :)
dlondon
  • February 23, 2016
Hi Guys,
Thanks for that info. I'll get a snapshot done (always good to have a plan B) and then do as you say.
Regards,
David
