Upgrading to Monterey remotely and automatic
  • October 29, 2021
  • 15 replies
  • 111 views
I created a policy which executes the following command
'/Applications/Install macOS Monterey.app/Contents/Resources/startosinstall' --agreetolicense --nointeraction --forcequitapps
via the Files and Processes --> Execute Command field on Macs which are capable of Monterey and do have the installer downloaded.
Although the command is correct AND the Macs did the upgrade the logged result of the command is:
/bin/sh: /Applications/Install macOS Monterey.app/Contents/Resources/startosinstall: No such file or directory
Does anybody have an idea why?
It is misleading that the log shows "No such file or directory" although the command is run properly.
AtillaTheC
  • November 2, 2021
What happens if you change it to:
/Applications/Install\\ macOS\\ Monterey.app/Contents/Resources/startosinstall
bwoods
  • November 2, 2021
Always drag your path into terminal and copy that output into your script/ exececute command.
  • November 2, 2021
I haven't tested that yet but I will. Thank you.
  • November 2, 2021
@bwoods You recommend this to get rid off formatted text, right?
bwoods
  • November 3, 2021
Correct.
  • November 3, 2021
I cannot execute any command :(, sorry you will have the command you use in the MDM.
  • November 5, 2021
I tested changing it but the error message is exactly the same.
bwoods
  • November 8, 2021
try removing the single quotes from your path.
  • November 9, 2021
I did that like @AtillaTheC suggested but that did not help.
bwoods
  • November 9, 2021
Are you dragging the startosinstall into terminal directly and then pasting the path into your script/command?
  • November 15, 2021
EDIT
  • November 16, 2021
I did that, yes.
AtillaTheC
  • November 16, 2021
I did that, yes.
check a reply I made to another post with a working script
  • January 8, 2023
Not sure it helps your case but FYI I ran:
/Applications/Install\\ macOS\\ Monterey.app/Contents/Resources/startosinstall --agreetolicense --nointeraction --forcequitapps
remotely through ARD and it did work. Of course, the central requirement is that the installer app exist in that location in the first place. Not a direct answer, but maybe a workaround if it helps anyone.
  • January 9, 2023
UPDATE (should have tried this first before posting). So I had to make a policy to copy the dmg/app to the correct location anyway since JAMF is much faster than ARD with the file size.  I tried making a "step 2" policy rigged to run after the 1st/copy that only did the exact cmd posted above, and success! Automatic updating underway.  Is it possible your cmd was just running before your actual copy completed or anything? Anyway, that got things working for me.
