User Environment not working?
  • February 22, 2012
  • 4 replies
  • 25 views
I created a dock, global pref.and desktop pattern with Composer 8.43. It created a .pkg (or .dmg) file then I re-imaged a new machine and had this run during the image process. After logging into the new machine none of these settings are set. The .pkg ran but the dock, background and global pref. are default. Should this be in a script?
Thanks
Best answer by rob_potvin
you got to make it a dmg and not a pkg and you want to then FUT (Fill User Templates) and FEU (Fill Existing users) check boxes checked when sending out the DMG.
Cheers
rob_potvin
  • Employee
  • February 22, 2012
Cheers
  • February 23, 2012
Excellent! Thanks.
  • September 10, 2013
What if I do only FUT?
Does it make the change only to users who log in for the first time after the policy has been pushed? Because, that is what I'm looking for.
bentoms
Forum|alt.badge.img+35
Yep.
