Hey all,
So in trying to use DEP for our new roll outs I'm struggling to recreate our policies that have up until this point been based on computer name. I think I can use DEPNotify and an attached script to call what I want to happen, however I have 2 specific things I want to write in.
  1. I want to onlyhave it prompt me to fill in a name if its not already got a correct name. In our case names are building-position (or room number) and barcode. So for teacher machines its HS-Teacher12345. So Im trying to make logic that looks at the JSS and will tell if its generically named, or has gotten a name previously. If it previously has gotten a name, I want it to populate it with that name. I'm just not sure if putting it through DEP wipes the name when reimaging or if (like on iPads) once in the JSS it uses the name that JSS has saved instead of "MacBook Air".
  2. I want to run extra policies in the script based on the name IE Admin/Teacher/Student
If anyone has any suggestions based on the attached script if I can make this logic happen, thanks in advance!
**Gabe Shackney
# Version 2.0.1
# License information
# Copyright 2018 Jamf Professional Services
# Permission is hereby granted, free of charge, to any person obtaining a copy of this
# software and associated documentation files (the "Software"), to deal in the Software
# without restriction, including without limitation the rights to use, copy, modify, merge,
# publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons
# to whom the Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in all copies or
# substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED,
# INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR
# PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE
# FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR
# OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
# General Information
# This script is designed to make implementation of DEPNotify very easy with limited
# scripting knowledge. The section below has variables that may be modified to customize
# the end user experience. DO NOT modify things in or below the CORE LOGIC area unless
# major testing and validation is performed.
# More information at: https://github.com/jamfprofessionalservices/DEP-Notify
# Testing Mode
# Testing flag will enable the following things to change:
# Auto removal of BOM files to reduce errors
# Sleep commands instead of policies or other changes being called
# Quit Key set to command + control + x
  TESTING_MODE=true # Set variable to true or false
# General Appearance
# Flag the app to open fullscreen or as a window
  FULLSCREEN=true # Set variable to true or false
# Banner image can be 600px wide by 100px high. Images will be scaled to fit
# If this variable is left blank, the generic image will appear. If using custom Self
# Service branding, please see the Customized Self Service Branding area below
  BANNER_IMAGE_PATH="/Applications/Self Service.app/Contents/Resources/AppIcon.icns"
# Main heading that will be displayed under the image
# If this variable is left blank, the generic banner will appear
  BANNER_TITLE="Welcome to Princeton Public Schools!"
# Paragraph text that will display under the main heading. For a new line, use
# If this variable is left blank, the generic message will appear. Leave single
# quotes below as double quotes will break the new lines.
  MAIN_TEXT='Imaging of this computer may take up to 30 minutes, please be stand by...'
# Initial Start Status text that shows as things are firing up
  INITAL_START_STATUS="Initial Configuration Starting..."
# Text that will display in the progress bar
  INSTALL_COMPLETE_TEXT="Configuration Complete!"
# Complete messaging to the end user can ether be a button at the bottom of the
# app with a modification to the main window text or a dropdown alert box. Default
# value set to false and will use buttons instead of dropdown messages.
  COMPLETE_METHOD_DROPDOWN_ALERT=false # Set variable to true or false
# Script designed to automatically logout user to start FileVault process if
# deferred enablement is detected. Text displayed if deferred status is on.
  # Option for dropdown alert box
    FV_ALERT_TEXT=""
  # Options if not using dropdown alert box
    FV_COMPLETE_MAIN_TEXT=''
    FV_COMPLETE_BUTTON_TEXT="Logout"
# Text that will display inside the alert once policies have finished
    COMPLETE_ALERT_TEXT="Your Mac is now finished with initial setup and configuration. Press Quit to get started!"
    COMPLETE_MAIN_TEXT='Your Mac is now finished with initial setup and configuration.'
    COMPLETE_BUTTON_TEXT="Get Started!"
# Plist Configuration
# The menu.depnotify.plist contains more and more things that configure the DEPNotify app
# You may want to save the file for purposes like verifying EULA acceptance or validating
# other options.
# Plist Save Location
  # This wrapper allows variables that are created later to be used but also allow for
  # configuration of where the plist is stored
    INFO_PLIST_WRAPPER (){
      DEP_NOTIFY_USER_INPUT_PLIST="/Users/$CURRENT_USER/Library/Preferences/menu.nomad.DEPNotifyUserInput.plist"
# Status Text Alignment
  # The status text under the progress bar can be configured to be left, right, or center
    STATUS_TEXT_ALIGN="center"
# Help Button Configuration
  # The help button was changed to a popup. Button will appear if title is populated.
    HELP_BUBBLE_TITLE="Need Help?"
    HELP_BUBBLE_BODY="Contact the Princeton Public School's Technology Office at 609-806-4299"
# Error Screen Text
# If testing mode is false and configuration files are present, this text will appear to
# the end user and asking them to contact IT. Limited window options here as the
# assumption is that they need to call IT. No continue or exit buttons will show for
# DEP Notify window and it will not show in fullscreen. IT staff will need to use Terminal
# or Activity Monitor to kill DEP Notify.
  ERROR_BANNER_TITLE="Uh oh, Something Needs Fixing!"
  ERROR_MAIN_TEXT='Something went wrong.  Please contact the Princeton Public Schools Technology Office at 609-806-4299'
# Error status message that is displayed under the progress bar
  ERROR_STATUS="Setup Failed"
# Policy Variable to Modify
# The policy array must be formatted "Progress Bar text,customTrigger". These will be
# run in order as they appear below.
  POLICY_ARRAY=(
    "Installing Adobe Reader,adobeReader"
    "Installing Chrome,chrome"
    "Installing Firefox,firefox"
    "Installing Java,java"
    "Installing Office,msOffice"
    "Installing Critical Updates,updateSoftware"
# Caffeinate / No Sleep Configuration
# Flag script to keep the computer from sleeping. BE VERY CAREFUL WITH THIS FLAG!
# This flag could expose your data to risk by leaving an unlocked computer wide open.
# Only recommended if you are using fullscreen mode and have a logout taking place at
# the end of configuration (like for FileVault). Some folks may use this in workflows
# where IT staff are the primary people setting up the device. The device will be
# allowed to sleep again once the DEPNotify app is quit as caffeinate is looking
# at DEPNotify's process ID.
  NO_SLEEP=true
# Customized Self Service Branding
# Flag for using the custom branding icon from Self Service and Jamf Pro
# This will override the banner image specified above. If you have changed the
# name of Self Service, make sure to modify the Self Service name below.
# Please note, custom branding is downloaded from Jamf Pro after Self Service has opened
# at least one time. The script is designed to wait until the files have been downloaded.
# This could take a few minutes depending on server and network resources.
  SELF_SERVICE_CUSTOM_BRANDING=true # Set variable to true or false
# If using a name other than Self Service with Custom branding. Change the
# name with the SELF_SERVICE_APP_NAME variable below. Keep .app on the end
  SELF_SERVICE_APP_NAME="Self Service.app"
# EULA Variables to Modify
# EULA configuration
  EULA_ENABLED=false # Set variable to true or false
  # EULA status bar text
    EULA_STATUS="Waiting on completion of EULA acceptance"
  # EULA button text on the main screen
    EULA_BUTTON="Read and Agree to EULA"
  # EULA Screen Title
    EULA_MAIN_TITLE="Organization End User License Agreement"
  # EULA Subtitle
    EULA_SUBTITLE="Please agree to the following terms and conditions to start configuration of this Mac"
  # Path to the EULA file you would like the user to read and agree to. It is
  # best to package this up with Composer or another tool and deliver it to a
  # shared area like /Users/Shared/
    EULA_FILE_PATH="/Users/Shared/eula.txt"
# Registration Variables to Modify
# Registration window configuration
  REGISTRATION_ENABLED=false # Set variable to true or false
  # Registration window title
    REGISTRATION_TITLE="Register Mac at Organization"
  # Registration status bar text
    REGISTRATION_STATUS="Waiting on completion of computer registration"
  # Registration window submit or finish button text
    REGISTRATION_BUTTON="Register Your Mac"
  # The text and pick list sections below will write the following lines out for
  # end users. Use the variables below to configure what the sentence says
  # Ex: Setting Computer Name to macBook0132
    REGISTRATION_BEGIN_WORD="Setting"
    REGISTRATION_MIDDLE_WORD="to"
  # Registration window can have up to two text fields. Leaving the text display
  # variable empty will hide the input box. Display text is to the side of the
  # input and placeholder text is the gray text inside the input box.
  # Registration window can have up to four dropdown / pick list inputs. Leaving
  # the pick display variable empty will hide the dropdown / pick list.
  # First Text Field
    # Text Field Label
      REG_TEXT_LABEL_1="Computer Name"
    # Place Holder Text
      REG_TEXT_LABEL_1_PLACEHOLDER="HS-TeacherBarcode"
    # Optional flag for making the field an optional input for end user
      REG_TEXT_LABEL_1_OPTIONAL="false" # Set variable to true or false
    # Help Bubble for Input. If title left blank, this will not appear
      REG_TEXT_LABEL_1_HELP_TITLE="Computer Name Field"
      REG_TEXT_LABEL_1_HELP_TEXT="This name must be set to the 2 letter abbreviation for your building, followed by a dash then either Teacher or Admin followed by the barcode of the computer."
    # Logic below was put in this section rather than in core code as folks may
    # want to change what the field does. This is a function that gets called
    # when needed later on. BE VERY CAREFUL IN CHANGING THE FUNCTION!
      REG_TEXT_LABEL_1_LOGIC (){
        REG_TEXT_LABEL_1_VALUE=$(defaults read "$DEP_NOTIFY_USER_INPUT_PLIST" "$REG_TEXT_LABEL_1")
        if [ "$REG_TEXT_LABEL_1_OPTIONAL" = true ] && [ "$REG_TEXT_LABEL_1_VALUE" = "" ]; then
          echo "Status: $REG_TEXT_LABEL_1 was left empty. Skipping..." >> "$DEP_NOTIFY_LOG"
          echo "$(date "+%a %h %d %H:%M:%S"): $REG_TEXT_LABEL_1 was set to optional and was left empty. Skipping..." >> "$DEP_NOTIFY_DEBUG"
          sleep 5
          echo "Status: $REGISTRATION_BEGIN_WORD $REG_TEXT_LABEL_1 $REGISTRATION_MIDDLE_WORD $REG_TEXT_LABEL_1_VALUE" >> "$DEP_NOTIFY_LOG"
          if [ "$TESTING_MODE" = true ]; then
            sleep 10
            "$JAMF_BINARY" setComputerName -name "$REG_TEXT_LABEL_1_VALUE"
            sleep 5
  # Second Text Field
    # Text Field Label
      REG_TEXT_LABEL_2="Barcode"
    # Place Holder Text
      REG_TEXT_LABEL_2_PLACEHOLDER="XXXXX"
      REG_TEXT_LABEL_2_OPTIONAL="false" # Set variable to true or false
      REG_TEXT_LABEL_2_HELP_TITLE="Barcode Field"
      #REG_TEXT_LABEL_2_HELP_TEXT="This field is used to give an updated asset tag to our asset management system. If you do not know your asset tag number, please skip this field."
      REG_TEXT_LABEL_2_LOGIC (){
        REG_TEXT_LABEL_2_VALUE=$(defaults read "$DEP_NOTIFY_USER_INPUT_PLIST" "$REG_TEXT_LABEL_2")
        if [ "$REG_TEXT_LABEL_2_OPTIONAL" = true ] && [ "$REG_TEXT_LABEL_2_VALUE" = "" ]; then
          echo "Status: $REG_TEXT_LABEL_2 was left empty. Skipping..." >> "$DEP_NOTIFY_LOG"
          echo "$(date "+%a %h %d %H:%M:%S"): $REG_TEXT_LABEL_2 was set to optional and was left empty. Skipping..." >> "$DEP_NOTIFY_DEBUG"
          sleep 5
          echo "Status: $REGISTRATION_BEGIN_WORD $REG_TEXT_LABEL_2 $REGISTRATION_MIDDLE_WORD $REG_TEXT_LABEL_2_VALUE" >> "$DEP_NOTIFY_LOG"
             sleep 10
            "$JAMF_BINARY" recon -assetTag "$REG_TEXT_LABEL_2_VALUE"
  # Popup 1
    # Label for the popup
      REG_POPUP_LABEL_1=""
    # Array of options for the user to select
      REG_POPUP_LABEL_1_OPTIONS=(
        "Amsterdam"
        "Eau Claire"
        "Minneapolis"
      REG_POPUP_LABEL_1_HELP_TITLE=""
      REG_POPUP_LABEL_1_HELP_TEXT="Please choose the appropriate building for where you normally work. This is important for inventory purposes."
      REG_POPUP_LABEL_1_LOGIC (){
        REG_POPUP_LABEL_1_VALUE=$(defaults read "$DEP_NOTIFY_USER_INPUT_PLIST" "$REG_POPUP_LABEL_1")
        echo "Status: $REGISTRATION_BEGIN_WORD $REG_POPUP_LABEL_1 $REGISTRATION_MIDDLE_WORD $REG_POPUP_LABEL_1_VALUE" >> "$DEP_NOTIFY_LOG"
           sleep 10
          "$JAMF_BINARY" recon -building "$REG_POPUP_LABEL_1_VALUE"
  # Popup 2
      REG_POPUP_LABEL_2=""
      REG_POPUP_LABEL_2_OPTIONS=(
        "Customer Onboarding"
        "Professional Services"
        "Sales Engineering"
      REG_POPUP_LABEL_2_HELP_TITLE="Department Dropdown Field"
      REG_POPUP_LABEL_2_HELP_TEXT="Please choose the appropriate department for where you normally work. This is important for inventory purposes."
      REG_POPUP_LABEL_2_LOGIC (){
        REG_POPUP_LABEL_2_VALUE=$(defaults read "$DEP_NOTIFY_USER_INPUT_PLIST" "$REG_POPUP_LABEL_2")
        echo "Status: $REGISTRATION_BEGIN_WORD $REG_POPUP_LABEL_2 $REGISTRATION_MIDDLE_WORD $REG_POPUP_LABEL_2_VALUE" >> "$DEP_NOTIFY_LOG"
           sleep 10
          "$JAMF_BINARY" recon -department "$REG_POPUP_LABEL_2_VALUE"
  # Popup 3 - Code is here but currently unused
      REG_POPUP_LABEL_3=""
      REG_POPUP_LABEL_3_OPTIONS=(
        "Option 1"
        "Option 2"
        "Option 3"
      REG_POPUP_LABEL_3_HELP_TITLE=""
      REG_POPUP_LABEL_3_HELP_TEXT="This dropdown is currently not in use. All code is here ready for you to use. It can also be hidden by removing the contents of the REG_POPUP_LABEL_3 variable."
      REG_POPUP_LABEL_3_LOGIC (){
        REG_POPUP_LABEL_3_VALUE=$(defaults read "$DEP_NOTIFY_USER_INPUT_PLIST" "$REG_POPUP_LABEL_3")
        echo "Status: $REGISTRATION_BEGIN_WORD $REG_POPUP_LABEL_3 $REGISTRATION_MIDDLE_WORD $REG_POPUP_LABEL_3_VALUE" >> "$DEP_NOTIFY_LOG"
          sleep 10
          sleep 10
  # Popup 4 - Code is here but currently unused
      REG_POPUP_LABEL_4=""
      REG_POPUP_LABEL_4_OPTIONS=(
        "Option 1"
        "Option 2"
        "Option 3"
      REG_POPUP_LABEL_4_HELP_TITLE=""
      3REG_POPUP_LABEL_4_HELP_TEXT="This dropdown is currently not in use. All code is here ready for you to use. It can also be hidden by removing the contents of the REG_POPUP_LABEL_4 variable."
      REG_POPUP_LABEL_4_LOGIC (){
       REG_POPUP_LABEL_4_VALUE=$(defaults read "$DEP_NOTIFY_USER_INPUT_PLIST" "$REG_POPUP_LABEL_4")
        echo "Status: $REGISTRATION_BEGIN_WORD $REG_POPUP_LABEL_4 $REGISTRATION_MIDDLE_WORD $REG_POPUP_LABEL_4_VALUE" >> "$DEP_NOTIFY_LOG"
          sleep 10
          sleep 10
# Core Script Logic - Don't Change Without Major Testing
# Variables for File Paths
  JAMF_BINARY="/usr/local/bin/jamf"
  FDE_SETUP_BINARY="/usr/bin/fdesetup"
  DEP_NOTIFY_APP="/Applications/Utilities/DEPNotify.app"
  DEP_NOTIFY_LOG="/var/tmp/depnotify.log"
  DEP_NOTIFY_DEBUG="/var/tmp/depnotifyDebug.log"
  DEP_NOTIFY_DONE="/var/tmp/com.depnotify.provisioning.done"
# Pulling from Policy parameters to allow true/false flags to be set. More info
# can be found on https://www.jamf.com/jamf-nation/articles/146/script-parameters
# These will override what is specified in the script above.
  # Testing Mode
    if [ "$4" != "" ]; then TESTING_MODE="$4"; fi
  # Fullscreen Mode
    if [ "$5" != "" ]; then FULLSCREEN="$5"; fi
  # No Sleep / Caffeinate Mode
    if [ "$6" != "" ]; then NO_SLEEP="$6"; fi
  # Self Service Custom Branding
    if [ "$7" != "" ]; then SELF_SERVICE_CUSTOM_BRANDING="$7"; fi
  # Complete method dropdown or main screen
    if [ "$8" != "" ]; then COMPLETE_METHOD_DROPDOWN_ALERT="$8"; fi
  # EULA Mode
    if [ "$9" != "" ]; then EULA_ENABLED="$9"; fi
  # Registration Mode
    if [ "${10}" != "" ]; then REGISTRATION_ENABLED="${10}"; fi
# Standard Testing Mode Enhancements
    # Removing old config file if present (Testing Mode Only)
      if [ -f "$DEP_NOTIFY_LOG" ]; then rm "$DEP_NOTIFY_LOG"; fi
      if [ -f "$DEP_NOTIFY_DONE" ]; then rm "$DEP_NOTIFY_DONE"; fi
      if [ -f "$DEP_NOTIFY_DEBUG" ]; then rm "$DEP_NOTIFY_DEBUG"; fi
    # Setting Quit Key set to command + control + x (Testing Mode Only)
      echo "Command: QuitKey: x" >> "$DEP_NOTIFY_LOG"
# Validating true/false flags
  if [ "$TESTING_MODE" != true ] && [ "$TESTING_MODE" != false ]; then
    echo "$(date "+%a %h %d %H:%M:%S"): Testing configuration not set properly. Currently set to $TESTING_MODE. Please update to true or false." >> "$DEP_NOTIFY_DEBUG"
    exit 1
  if [ "$FULLSCREEN" != true ] && [ "$FULLSCREEN" != false ]; then
    echo "$(date "+%a %h %d %H:%M:%S"): Fullscreen configuration not set properly. Currently set to $FULLSCREEN. Please update to true or false." >> "$DEP_NOTIFY_DEBUG"
    exit 1
  if [ "$NO_SLEEP" != true ] && [ "$NO_SLEEP" != false ]; then
    echo "$(date "+%a %h %d %H:%M:%S"): Sleep configuration not set properly. Currently set to $NO_SLEEP. Please update to true or false." >> "$DEP_NOTIFY_DEBUG"
    exit 1
  if [ "$SELF_SERVICE_CUSTOM_BRANDING" != true ] && [ "$SELF_SERVICE_CUSTOM_BRANDING" != false ]; then
    echo "$(date "+%a %h %d %H:%M:%S"): Self Service Custom Branding configuration not set properly. Currently set to $SELF_SERVICE_CUSTOM_BRANDING. Please update to true or false." >> "$DEP_NOTIFY_DEBUG"
    exit 1
  if [ "$COMPLETE_METHOD_DROPDOWN_ALERT" != true ] && [ "$COMPLETE_METHOD_DROPDOWN_ALERT" != false ]; then
    echo "$(date "+%a %h %d %H:%M:%S"): Completion alert method not set properly. Currently set to $COMPLETE_METHOD_DROPDOWN_ALERT. Please update to true or false." >> "$DEP_NOTIFY_DEBUG"
    exit 1
  if [ "$EULA_ENABLED" != true ] && [ "$EULA_ENABLED" != false ]; then
    echo "$(date "+%a %h %d %H:%M:%S"): EULA configuration not set properly. Currently set to $EULA_ENABLED. Please update to true or false." >> "$DEP_NOTIFY_DEBUG"
    exit 1
  if [ "$REGISTRATION_ENABLED" != true ] && [ "$REGISTRATION_ENABLED" != false ]; then
    echo "$(date "+%a %h %d %H:%M:%S"): Registration configuration not set properly. Currently set to $REGISTRATION_ENABLED. Please update to true or false." >> "$DEP_NOTIFY_DEBUG"
    exit 1
# Run DEP Notify will run after Apple Setup Assistant
  SETUP_ASSISTANT_PROCESS=$(pgrep -l "Setup Assistant")
  until [ "$SETUP_ASSISTANT_PROCESS" = "" ]; do
    echo "$(date "+%a %h %d %H:%M:%S"): Setup Assistant Still Running. PID $SETUP_ASSISTANT_PROCESS." >> "$DEP_NOTIFY_DEBUG"
    sleep 1
  done
# Checking to see if the Finder is running now before continuing. This can help
# in scenarios where an end user is not configuring the device.
  FINDER_PROCESS=$(pgrep -l "Finder")
  until [ "$FINDER_PROCESS" != "" ]; do
    echo "$(date "+%a %h %d %H:%M:%S"): Finder process not found. Assuming device is at login screen." >> "$DEP_NOTIFY_DEBUG"
    sleep 1
  done
# After the Apple Setup completed. Now safe to grab the current user.
  CURRENT_USER=$(/usr/bin/python -c 'from SystemConfiguration import SCDynamicStoreCopyConsoleUser; import sys; username = (SCDynamicStoreCopyConsoleUser(None, None, None) or [None])[0]; username = [username,""][username in [u"loginwindow", None, u""]]; sys.stdout.write(username + "
  echo "$(date "+%a %h %d %H:%M:%S"): Current user set to $CURRENT_USER." >> "$DEP_NOTIFY_DEBUG"
# Adding Check and Warning if Testing Mode is off and BOM files exist
  if [[ ( -f "$DEP_NOTIFY_LOG" || -f "$DEP_NOTIFY_DONE" ) && "$TESTING_MODE" = false ]]; then
    echo "$(date "+%a %h %d %H:%M:%S"): TESTING_MODE set to false but config files were found in /var/tmp. Letting user know and exiting." >> "$DEP_NOTIFY_DEBUG"
    mv "$DEP_NOTIFY_LOG" "/var/tmp/depnotify_old.log"
    echo "Command: MainTitle: $ERROR_BANNER_TITLE" >> "$DEP_NOTIFY_LOG"
    echo "Command: MainText: $ERROR_MAIN_TEXT" >> "$DEP_NOTIFY_LOG"
    echo "Status: $ERROR_STATUS" >> "$DEP_NOTIFY_LOG"
    sudo -u "$CURRENT_USER" open -a "$DEP_NOTIFY_APP" --args -path "$DEP_NOTIFY_LOG"
    sleep 5
    exit 1
# If SELF_SERVICE_CUSTOM_BRANDING is set to true. Loading the updated icon
  if [ "$SELF_SERVICE_CUSTOM_BRANDING" = true ]; then
    open -a "/Applications/$SELF_SERVICE_APP_NAME" --hide
  # Loop waiting on the branding image to properly show in the users library
  CUSTOM_BRANDING_PNG="/Users/$CURRENT_USER/Library/Application Support/com.jamfsoftware.selfservice.mac/Documents/Images/brandingimage.png"
    until [ -f "$CUSTOM_BRANDING_PNG" ]; do
      echo "$(date "+%a %h %d %H:%M:%S"): Waiting for branding image from Jamf Pro." >> "$DEP_NOTIFY_DEBUG"
       sleep 1
    done
  # Setting Banner Image for DEP Notify to Self Service Custom Branding
    BANNER_IMAGE_PATH="$CUSTOM_BRANDING_PNG"
  # Closing Self Service
    SELF_SERVICE_PID=$(pgrep -l "$(echo "$SELF_SERVICE_APP_NAME" | cut -d "." -f1)" | cut -d " " -f1)
    echo "$(date "+%a %h %d %H:%M:%S"): Self Service custom branding icon has been loaded. Killing Self Service PID $SELF_SERVICE_PID." >> "$DEP_NOTIFY_DEBUG"
    kill "$SELF_SERVICE_PID"
# Setting custom image if specified
  if [ "$BANNER_IMAGE_PATH" != "" ]; then  echo "Command: Image: $BANNER_IMAGE_PATH" >> "$DEP_NOTIFY_LOG"; fi
# Setting custom title if specified
  if [ "$BANNER_TITLE" != "" ]; then echo "Command: MainTitle: $BANNER_TITLE" >> "$DEP_NOTIFY_LOG"; fi
# Setting custom main text if specified
  if [ "$MAIN_TEXT" != "" ]; then echo "Command: MainText: $MAIN_TEXT" >> "$DEP_NOTIFY_LOG"; fi
# General Plist Configuration
  # Calling function to set the INFO_PLIST_PATH
    INFO_PLIST_WRAPPER
  # The plist information below
    DEP_NOTIFY_CONFIG_PLIST="/Users/$CURRENT_USER/Library/Preferences/menu.nomad.DEPNotify.plist"
  # If testing mode is on, this will remove some old configuration files
    if [ "$TESTING_MODE" = true ] && [ -f "$DEP_NOTIFY_CONFIG_PLIST" ]; then rm "$DEP_NOTIFY_CONFIG_PLIST"; fi
    if [ "$TESTING_MODE" = true ] && [ -f "$DEP_NOTIFY_USER_INPUT_PLIST" ]; then rm "$DEP_NOTIFY_USER_INPUT_PLIST"; fi
  # Setting default path to the plist which stores all the user completed info
    defaults write "$DEP_NOTIFY_CONFIG_PLIST" pathToPlistFile "$DEP_NOTIFY_USER_INPUT_PLIST"
  # Setting status text alignment
    defaults write "$DEP_NOTIFY_CONFIG_PLIST" statusTextAlignment "$STATUS_TEXT_ALIGN"
  # Setting help button
    if [ "$HELP_BUBBLE_TITLE" != "" ]; then
      defaults write "$DEP_NOTIFY_CONFIG_PLIST" helpBubble -array-add "$HELP_BUBBLE_TITLE"
      defaults write "$DEP_NOTIFY_CONFIG_PLIST" helpBubble -array-add "$HELP_BUBBLE_BODY"
# EULA Configuration
  if [ "$EULA_ENABLED" =  true ]; then
    DEP_NOTIFY_EULA_DONE="/var/tmp/com.depnotify.agreement.done"
    # If testing mode is on, this will remove EULA specific configuration files
      if [ "$TESTING_MODE" = true ] && [ -f "$DEP_NOTIFY_EULA_DONE" ]; then rm "$DEP_NOTIFY_EULA_DONE"; fi
    # Writing title, subtitle, and EULA txt location to plist
      defaults write "$DEP_NOTIFY_CONFIG_PLIST" EULAMainTitle "$EULA_MAIN_TITLE"
      defaults write "$DEP_NOTIFY_CONFIG_PLIST" EULASubTitle "$EULA_SUBTITLE"
      defaults write "$DEP_NOTIFY_CONFIG_PLIST" pathToEULA "$EULA_FILE_PATH"
    # Setting ownership of EULA file
      chown "$CURRENT_USER:staff" "$EULA_FILE_PATH"
      chmod 444 "$EULA_FILE_PATH"
# Registration Plist Configuration
  if [ "$REGISTRATION_ENABLED" = true ]; then
    DEP_NOTIFY_REGISTER_DONE="/var/tmp/com.depnotify.registration.done"
    # If testing mode is on, this will remove registration specific configuration files
      if [ "$TESTING_MODE" = true ] && [ -f "$DEP_NOTIFY_REGISTER_DONE" ]; then rm "$DEP_NOTIFY_REGISTER_DONE"; fi
    # Main Window Text Configuration
      defaults write "$DEP_NOTIFY_CONFIG_PLIST" registrationMainTitle "$REGISTRATION_TITLE"
      defaults write "$DEP_NOTIFY_CONFIG_PLIST" registrationButtonLabel "$REGISTRATION_BUTTON"
      defaults write "$DEP_NOTIFY_CONFIG_PLIST" registrationPicturePath "$BANNER_IMAGE_PATH"
    # First Text Box Configuration
      if [ "$REG_TEXT_LABEL_1" != "" ]; then
        defaults write "$DEP_NOTIFY_CONFIG_PLIST" textField1Label "$REG_TEXT_LABEL_1"
        defaults write "$DEP_NOTIFY_CONFIG_PLIST" textField1Placeholder "$REG_TEXT_LABEL_1_PLACEHOLDER"
        defaults write "$DEP_NOTIFY_CONFIG_PLIST" textField1IsOptional "$REG_TEXT_LABEL_1_OPTIONAL"
        # Code for showing the help box if configured
          if [ "$REG_TEXT_LABEL_1_HELP_TITLE" != "" ]; then
              defaults write "$DEP_NOTIFY_CONFIG_PLIST" textField1Bubble -array-add "$REG_TEXT_LABEL_1_HELP_TITLE"
              defaults write "$DEP_NOTIFY_CONFIG_PLIST" textField1Bubble -array-add "$REG_TEXT_LABEL_1_HELP_TEXT"
    # Second Text Box Configuration
      if [ "$REG_TEXT_LABEL_2" != "" ]; then
        defaults write "$DEP_NOTIFY_CONFIG_PLIST" textField2Label "$REG_TEXT_LABEL_2"
        defaults write "$DEP_NOTIFY_CONFIG_PLIST" textField2Placeholder "$REG_TEXT_LABEL_2_PLACEHOLDER"
        defaults write "$DEP_NOTIFY_CONFIG_PLIST" textField2IsOptional "$REG_TEXT_LABEL_2_OPTIONAL"
          if [ "$REG_TEXT_LABEL_2_HELP_TITLE" != "" ]; then
              defaults write "$DEP_NOTIFY_CONFIG_PLIST" textField2Bubble -array-add "$REG_TEXT_LABEL_2_HELP_TITLE"
              defaults write "$DEP_NOTIFY_CONFIG_PLIST" textField2Bubble -array-add "$REG_TEXT_LABEL_2_HELP_TEXT"
    # Popup 1
      if [ "$REG_POPUP_LABEL_1" != "" ]; then
        defaults write "$DEP_NOTIFY_CONFIG_PLIST" popupButton1Label "$REG_POPUP_LABEL_1"
          if [ "$REG_POPUP_LABEL_1_HELP_TITLE" != "" ]; then
            defaults write "$DEP_NOTIFY_CONFIG_PLIST" popupMenu1Bubble -array-add "$REG_POPUP_LABEL_1_HELP_TITLE"
            defaults write "$DEP_NOTIFY_CONFIG_PLIST" popupMenu1Bubble -array-add "$REG_POPUP_LABEL_1_HELP_TEXT"
        # Code for adding the items from the array above into the plist
          for REG_POPUP_LABEL_1_OPTION in "${REG_POPUP_LABEL_1_OPTIONS[@]}"; do
             defaults write "$DEP_NOTIFY_CONFIG_PLIST" popupButton1Content -array-add "$REG_POPUP_LABEL_1_OPTION"
          done
    # Popup 2
      if [ "$REG_POPUP_LABEL_2" != "" ]; then
        defaults write "$DEP_NOTIFY_CONFIG_PLIST" popupButton2Label "$REG_POPUP_LABEL_2"
          if [ "$REG_POPUP_LABEL_2_HELP_TITLE" != "" ]; then
            defaults write "$DEP_NOTIFY_CONFIG_PLIST" popupMenu2Bubble -array-add "$REG_POPUP_LABEL_2_HELP_TITLE"
            defaults write "$DEP_NOTIFY_CONFIG_PLIST" popupMenu2Bubble -array-add "$REG_POPUP_LABEL_2_HELP_TEXT"
          for REG_POPUP_LABEL_2_OPTION in "${REG_POPUP_LABEL_2_OPTIONS[@]}"; do
             defaults write "$DEP_NOTIFY_CONFIG_PLIST" popupButton2Content -array-add "$REG_POPUP_LABEL_2_OPTION"
          done
    # Popup 3
      if [ "$REG_POPUP_LABEL_3" != "" ]; then
        defaults write "$DEP_NOTIFY_CONFIG_PLIST" popupButton3Label "$REG_POPUP_LABEL_3"
          if [ "$REG_POPUP_LABEL_3_HELP_TITLE" != "" ]; then
            defaults write "$DEP_NOTIFY_CONFIG_PLIST" popupMenu3Bubble -array-add "$REG_POPUP_LABEL_3_HELP_TITLE"
            defaults write "$DEP_NOTIFY_CONFIG_PLIST" popupMenu3Bubble -array-add "$REG_POPUP_LABEL_3_HELP_TEXT"
          for REG_POPUP_LABEL_3_OPTION in "${REG_POPUP_LABEL_3_OPTIONS[@]}"; do
             defaults write "$DEP_NOTIFY_CONFIG_PLIST" popupButton3Content -array-add "$REG_POPUP_LABEL_3_OPTION"
          done
    # Popup 4
      if [ "$REG_POPUP_LABEL_4" != "" ]; then
        defaults write "$DEP_NOTIFY_CONFIG_PLIST" popupButton4Label "$REG_POPUP_LABEL_4"
          if [ "$REG_POPUP_LABEL_4_HELP_TITLE" != "" ]; then
            defaults write "$DEP_NOTIFY_CONFIG_PLIST" popupMenu4Bubble -array-add "$REG_POPUP_LABEL_4_HELP_TITLE"
            defaults write "$DEP_NOTIFY_CONFIG_PLIST" popupMenu4Bubble -array-add "$REG_POPUP_LABEL_4_HELP_TEXT"
          for REG_POPUP_LABEL_4_OPTION in "${REG_POPUP_LABEL_4_OPTIONS[@]}"; do
             defaults write "$DEP_NOTIFY_CONFIG_PLIST" popupButton4Content -array-add "$REG_POPUP_LABEL_4_OPTION"
          done
# Changing Ownership of the plist file
  chown "$CURRENT_USER":staff "$DEP_NOTIFY_CONFIG_PLIST"
  chmod 600 "$DEP_NOTIFY_CONFIG_PLIST"
# Opening the app after initial configuration
  if [ "$FULLSCREEN" = true ]; then
    sudo -u "$CURRENT_USER" open -a "$DEP_NOTIFY_APP" --args -path "$DEP_NOTIFY_LOG" -fullScreen
  elif [ "$FULLSCREEN" = false ]; then
# Grabbing the DEP Notify Process ID for use later
  DEP_NOTIFY_PROCESS=$(pgrep -l "DEPNotify" | cut -d " " -f1)
  until [ "$DEP_NOTIFY_PROCESS" != "" ]; do
    echo "$(date "+%a %h %d %H:%M:%S"): Waiting for DEPNotify to start to gather the process ID." >> "$DEP_NOTIFY_DEBUG"
    sleep 1
  done
# Using Caffeinate binary to keep the computer awake if enabled
  if [ "$NO_SLEEP" = true ]; then
    echo "$(date "+%a %h %d %H:%M:%S"): Caffeinating DEP Notify process. Process ID: $DEP_NOTIFY_PROCESS" >> "$DEP_NOTIFY_DEBUG"
    caffeinate -disu -w "$DEP_NOTIFY_PROCESS"&
# Adding an alert prompt to let admins know that the script is in testing mode
    echo "Command: Alert: DEP Notify is in TESTING_MODE. Script will not run Policies or other commands that make change to this computer."  >> "$DEP_NOTIFY_LOG"
# Adding nice text and a brief pause for prettiness
  echo "Status: $INITAL_START_STATUS" >> "$DEP_NOTIFY_LOG"
  sleep 5
# Setting the status bar
  # Counter is for making the determinate look nice. Starts at one and adds
  # more based on EULA, register, or other options.
    ADDITIONAL_OPTIONS_COUNTER=1
    if [ "$EULA_ENABLED" = true ]; then ((ADDITIONAL_OPTIONS_COUNTER++)); fi
    if [ "$REGISTRATION_ENABLED" = true ]; then ((ADDITIONAL_OPTIONS_COUNTER++))
      if [ "$REG_TEXT_LABEL_1" != "" ]; then ((ADDITIONAL_OPTIONS_COUNTER++)); fi
      if [ "$REG_TEXT_LABEL_2" != "" ]; then ((ADDITIONAL_OPTIONS_COUNTER++)); fi
      if [ "$REG_POPUP_LABEL_1" != "" ]; then ((ADDITIONAL_OPTIONS_COUNTER++)); fi
      if [ "$REG_POPUP_LABEL_2" != "" ]; then ((ADDITIONAL_OPTIONS_COUNTER++)); fi
      if [ "$REG_POPUP_LABEL_3" != "" ]; then ((ADDITIONAL_OPTIONS_COUNTER++)); fi
      if [ "$REG_POPUP_LABEL_4" != "" ]; then ((ADDITIONAL_OPTIONS_COUNTER++)); fi
  # Checking policy array and adding the count from the additional options above.
    ARRAY_LENGTH="$((${#POLICY_ARRAY[@]}+ADDITIONAL_OPTIONS_COUNTER))"
    echo "Command: Determinate: $ARRAY_LENGTH" >> "$DEP_NOTIFY_LOG"
# EULA Window Display Logic
    echo "Status: $EULA_STATUS" >> "$DEP_NOTIFY_LOG"
    echo "Command: ContinueButtonEULA: $EULA_BUTTON" >> "$DEP_NOTIFY_LOG"
    while [ ! -f "$DEP_NOTIFY_EULA_DONE" ]; do
      echo "$(date "+%a %h %d %H:%M:%S"): Waiting for user to accept EULA." >> "$DEP_NOTIFY_DEBUG"
      sleep 1
    done
# Registration Window Display Logic
    echo "Status: $REGISTRATION_STATUS" >> "$DEP_NOTIFY_LOG"
    echo "Command: ContinueButtonRegister: $REGISTRATION_BUTTON" >> "$DEP_NOTIFY_LOG"
    while [ ! -f "$DEP_NOTIFY_REGISTER_DONE" ]; do
      echo "$(date "+%a %h %d %H:%M:%S"): Waiting for user to complete registration." >> "$DEP_NOTIFY_DEBUG"
      sleep 1
    done
    # Running Logic For Each Registration Box
      if [ "$REG_TEXT_LABEL_1" != "" ]; then REG_TEXT_LABEL_1_LOGIC; fi
      if [ "$REG_TEXT_LABEL_2" != "" ]; then REG_TEXT_LABEL_2_LOGIC; fi
      if [ "$REG_POPUP_LABEL_1" != "" ]; then REG_POPUP_LABEL_1_LOGIC; fi
      if [ "$REG_POPUP_LABEL_2" != "" ]; then REG_POPUP_LABEL_2_LOGIC; fi
      if [ "$REG_POPUP_LABEL_3" != "" ]; then REG_POPUP_LABEL_3_LOGIC; fi
      if [ "$REG_POPUP_LABEL_4" != "" ]; then REG_POPUP_LABEL_4_LOGIC; fi
# Loop to run policies
  for POLICY in "${POLICY_ARRAY[@]}"; do
    echo "Status: $(echo "$POLICY" | cut -d ',' -f1)" >> "$DEP_NOTIFY_LOG"
      sleep 10
    elif [ "$TESTING_MODE" = false ]; then
      "$JAMF_BINARY" policy -event "$(echo "$POLICY" | cut -d ',' -f2)"
  done
# Nice completion text
  echo "Status: $INSTALL_COMPLETE_TEXT" >> "$DEP_NOTIFY_LOG"
# Check to see if FileVault Deferred enablement is active
  FV_DEFERRED_STATUS=$($FDE_SETUP_BINARY status | grep "Deferred" | cut -d ' ' -f6)
  # Logic to log user out if FileVault is detected. Otherwise, app will close.
    if [ "$FV_DEFERRED_STATUS" = "active" ] && [ "$TESTING_MODE" = true ]; then
      if [ "$COMPLETE_METHOD_DROPDOWN_ALERT" = true ]; then
        echo "Command: Quit: This is typically where your FV_LOGOUT_TEXT would be displayed. However, TESTING_MODE is set to true and FileVault deferred status is on." >> "$DEP_NOTIFY_LOG"
        echo "Command: MainText: TESTING_MODE is set to true and FileVault deferred status is on. Button effect is quit instead of logout.
 $FV_COMPLETE_MAIN_TEXT" >> "$DEP_NOTIFY_LOG"
        echo "Command: ContinueButton: Test $FV_COMPLETE_BUTTON_TEXT" >> "$DEP_NOTIFY_LOG"
    elif [ "$FV_DEFERRED_STATUS" = "active" ] && [ "$TESTING_MODE" = false ]; then
        echo "Command: Logout: $FV_ALERT_TEXT" >> "$DEP_NOTIFY_LOG"
        echo "Command: MainText: $FV_COMPLETE_MAIN_TEXT" >> "$DEP_NOTIFY_LOG"
        echo "Command: ContinueButtonLogout: $FV_COMPLETE_BUTTON_TEXT" >> "$DEP_NOTIFY_LOG"
        echo "Command: Quit: $COMPLETE_ALERT_TEXT" >> "$DEP_NOTIFY_LOG"
        echo "Command: MainText: $COMPLETE_MAIN_TEXT" >> "$DEP_NOTIFY_LOG"
        echo "Command: ContinueButton: $COMPLETE_BUTTON_TEXT" >> "$DEP_NOTIFY_LOG"
Princeton Public Schools**
You should look at the DEPNotify process I wrote. It also includes an Extension Attribute that pulls the computer record, checks if a value is populated, if not it will write it to the record. If the value is filled it will do nothing.
DEPNotify Launchd
General workflow:
1: Make a smart group called "Invalid Naming Scheme" and use Regex or hard code the values you DON'T want the machine name to have
2: Use the Jamf API to check if that computer is a member of the group
3: If it is, execute the policy to rename machine
4: Create an extension attribute to assign a group "Admin/Teacher/Student" based on the machine name
5: Make a script that executes a specific policy array based on the EA group
Alternatively, you can make multiple DEP assignments. We have one for Faculty/Staff and one for Lab/Checkouts. A smart group checks for membership of either of these and determines if something should be ran.
You can look at jmahlman's script to see how he handled policies based on a group (or cohort as he has it)
Hello gshackney,
This is how I am currently going about auto-naming the computers using the DEPNotify Starter script. I have added a few lines towards the bottom of the script to name the computer using our standard naming convention. Department prefix,D or L (laptop or desktop), and last 7 of the serial number. Once the user chooses the department that is then used for naming the computer. I hope this gives you some guidance on where to go with that or how to change me addition to make it work for you.
    IS_LAPTOP=`/usr/sbin/system_profiler SPHardwareDataType | grep "Model Identifier" | grep "Book"`
    serialNumber=$( system_profiler SPHardwareDataType | awk '/Serial Number/ { print $4; }')
    if [ "$IS_LAPTOP" != "" ]; then
      /usr/local/bin/jamf setComputerName -name "${REG_POPUP_LABEL_2_VALUE}-L${serialNumber: -7}"
      /usr/local/bin/jamf setComputerName -name "${REG_POPUP_LABEL_2_VALUE}-D${serialNumber: -7}"
