Answer
Using Extension Attributes on Device Enrollment
  • November 1, 2024
  • 4 replies
  • 51 views
I've currently got an extension attribute for "Brand" for our retail company and am wondering if there is anyway to have our iPads display a drop down during the enrollment stage to select the brand they belong to for the corresponding configurations to apply correctly?
I've seen how I can add text to the enrollment page but unsure how to link the extension attribute
Any help would be greatly appreciated.
Regards,
Danyon
Best answer by agungsujiwo
You can try Jamf Setup,
This feature makes it easy for you to create a brand list,
and when they choose, they will be able to Customize the device per role, Managed app config, and many more.
https://www.jamf.com/resources/product-documentation/jamf-setup/
https://www.jamf.com/resources/videos/advanced-jamf-setup-getting-the-most-out-of-shared-ios-devices-deployment/
agungsujiwo
  • November 1, 2024
Chubs
Forum|alt.badge.img+22
  • November 1, 2024
What Agung said.  JAMF Setup would be the route to go and it's super easy to customize (mostly).
You'd have to have the iPad go through enrollment and have Jamf Setup [and settings unfortunately] as the only thing visible on the home screen.  Make sure to have your smart groups created for the EAs and the configs you want applied/scoped to those smart groups.  The user would launch Jamf Setup after enrollment and it would provide the "brand" list.  User would select it, the EA would fill in the JSS, and smart group magic would do its thing.
  • November 6, 2024
Thanks @agungsujiwo @Chubs
This has achieved exactly what I was after! Much appreciated :)
  • November 14, 2024
Thank you so much for the solution.
