Using NetInstall Creator with FV2 Encripted Drives.
  • September 5, 2014
  • 23 views
has anyone encountered this? I ended up using my own .NBI When I use the NetInstall Creator, it gives me an error saying it cant find drive and casper imaging quits. Obviously because drive is encrypted and cant unlock without proper credentials. Only work around I have found is to boot from another source and delete encryption/filevault information.
I think NetInstall Creator should also have proper trouble tools like Disk Utility on the Menu and a few others. I have to resort to run all the commands manually, and not a good workflow for Technicians imaging machines. if anyone has implemented this in their enviroment, feedback would be helpful and appreciated.
Wagner
  • September 5, 2014
Yes, there's some discussion here. I asked for ability to add a script or way to wipe FV encrypted machines. Without it the tool is pretty useless for us, which is unfortunate as it is pretty slick.
https://jamfnation.jamfsoftware.com/discussion.html?id=9720
  • September 5, 2014
