I think I just answered my own question and wrote something that will
work. I ended up using some code from setWebProxy.sh, but much of it
is grabbed from elsewhere. Here it is for those that may want this...
I'm sure it would be cleaner in perl, but I don't know it yet. Jamf
comments are removed from the top to shorten this message.
# VALUES ARE SET HERE
proxyAddress="http://webconfig.company.com/pac/webconfig.pac"
OS=`/usr/bin/defaults read /System/Library/CoreServices/SystemVersion
ProductVersion | awk '{print substr($1,1,4)}'`
# Set Network Interfaces
if [[ "$OS" < "10.5" ]]; then
ethInt1=$(/System/Library/CoreServices/RemoteManagement/
ARDAgent.app/Contents/Support/networksetup -listnetworkserviceorder |
egrep [Ee]thernet | awk -F') ' '/()/ {print $2}' | awk 'NR==1');
ethInt2=$(/System/Library/CoreServices/RemoteManagement/
egrep [Ee]thernet | awk -F') ' '/()/ {print $2}' | awk 'NR==3');
airInt=$(/System/Library/CoreServices/RemoteManagement/
egrep [Aa]ir | awk -F') ' '/()/ {print $2}' | awk 'NR==1');
ethInt1=$(/usr/sbin/networksetup -listnetworkserviceorder |
ethInt2=$(/usr/sbin/networksetup -listnetworkserviceorder |
airInt=$(/usr/sbin/networksetup -listnetworkserviceorder |
# Set Proxy for Ethernet Interfaces
echo "Setting Etehrnet Interface proxy for OS $OS..."
/System/Library/CoreServices/RemoteManagement/ARDAgent.app/
Contents/Support/networksetup -setautoproxyurl "$ethInt1"
"$proxyAddress"
Contents/Support/networksetup -setautoproxyurl "$ethInt2"
"$proxyAddress"
echo "Setting Ethernet Interface proxy for OS $OS..."
/usr/sbin/networksetup -setautoproxyurl "$ethInt1"
"$proxyAddress"
/usr/sbin/networksetup -setautoproxyurl "$ethInt2"
"$proxyAddress"
#Set Proxy for Airport Interface
echo "Setting Airport Interface proxy for OS $OS..."
Contents/Support/networksetup -setautoproxyurl "$airInt" "$proxyAddress"
/usr/sbin/networksetup -setautoproxyurl "$airInt"
"$proxyAddress"
You can find the OS version a lot easier. Use sw_vers and case out for the
specific OS.
j
Argh, the networksetup command in 10.4 and below does not support the -
setproxyautoconfig flag. I'm testing to see if I can copy the
networksetup binary to a 10.4 machine to make it work; my guess is
that it won't.
I guess create and maintain separate scripts and set them up as custom trigger policies. Then set one master script that checks the OS via sw_vers command and does an if/then with a construct comparison and then triggers the custom trigger policy based on what the output is.
Thomas Larkin
TIS Department
KCKPS USD500
tlarki at kckps.org
blackberry: 913-449-7589
office: 913-627-0351
chown -R us /.base
Thanks Thomas... that is a good easy way to do it. My new problem
though is that I cannot seem to find a way to deploy a proxy pac file
url to 10.4 machines. We still have about 68 of them that this
solution doesn't work for.
Can you configure the file manually, and then snapshot that file change in Composer and use it to push that file out?
