Using "while getopts" in a script (script experts needed)
  • May 13, 2022
  • 0 replies
  • 14 views
I'm working on a script to check if an application is installed, if it is, what the version is. When I wrote the script and tested locally it worked fine, but I forgot the script in Jamf is actually passing the entire string as option 4, and won't pick up the individual arguments I used. This is the code that works fine on my machine:
while getopts "o:O:p:t:T:v:c:fsr?" opt do case "${opt}" in o) osMinVers=${OPTARG};; O) osMaxVers=${OPTARG};; p) appPath=${OPTARG};; t) jamfTrigger=${OPTARG};; T) patchName=${OPTARG};; v) appToUpdVers=${OPTARG};; c) verCheck=${OPTARG};; f) installIfMissing="true";; s) silent="true";; r) reboot="true";; ?) echo "Usage: macOSUpgradePrePostReqs.sh -o -O -p -t -T -v [-f -s -r]"; echo " -o <osMinVers>"; echo " -O <osMaxVers>"; echo " -p <appPath>"; echo " -t <jamfPatchTrigger>"; echo " -T <patchName>"; echo " -v <appToUpdVers>"; echo " -c Greater then or less then"; echo " g/G = application must be greater than the version specified"; echo " l/L = application must be less than the version specified"; echo " -f Install if Missing"; echo " -s Silent"; echo " -r Reboot"; exitFunc 90 esac done
My argument string is:
-o 18G1 -O 22Z9999 -p "/Applications/Symantec Endpoint Protection.app" -t SEPRemoval -T "Symantec Removal" -v 14.3.5055.3000 -c g
Any suggestions?
