vpp redownload call timed out <mdmclienterror:72>
  • February 18, 2019
  • 407 replies
  • 1242 views
Show first post
  • April 23, 2020
Please Apple, solve this issue, it is really frustrating. Especially in these times...
KyleEricson
  • May 11, 2020
Does anyone has a good workflow to go from VPP office apps to PKG apps. I need to revert now since Apple is no where near to fixing this issue.
  • May 11, 2020
@kerickson simply run the latest Office Suite installer and it will close the existing MAS apps and overwrite them.
  • May 11, 2020
Forum|alt.badge.img+15
  • May 11, 2020
Yeah, I was testing out MAS apps and the Office Suite installer. Installer worked flawlessly where the MAS apps was hit and miss on whether they installed or not. I decided to just remove MAS apps as a source for deploying/installing Office.
@pbowden I wasn't able to find a great uninstaller. Have you ran across one? I was looking to get one setup in case we need to uninstall O365/Teams and reinstall for any reason.
  • May 11, 2020
@bcbackes yeah, I was thinking at the weekend of putting an uninstaller together. There are two scenarios I can think of:
  1. You want to put Office into a factory defaults state. Basically, remove all Config files, keychain items, group containers, Outlook profile, etc but leave the app bundles intact in /Applications
  2. Do all of #1, and delete the app bundles in /Applications
I like the idea of #1 because I find that when Office isn’t working, people tend to delete the apps and get frustrated because the problem is usually one of the Config files. They also waste time by re-downloading the installer pkg from the CDN when this is very rarely the problem.
What do you think?
  • May 12, 2020
@pbowden Both options sound great. Like you said, option 1 brings it back to default. I'm thinking it would be similar to taking a snapshot of a VM right after you install Office, then, when things are messed up you restore it back to the part right after the install. That would certainly save time of having to redownload/install the app bundles.
However, I do see a benefit with option 2 as well. If there happens to be an issue during installation where something didn't install right, however, it wasn't bad enough to prevent the app from opening. In that situation I would like to nuc everything including the app bundles.
Nowadays there can be multiple variables on why things don't work correctly. For most tickets, I spend "x" amount on it before I decide it's time to uninstall/reinstall. I really hate to spend 3 hours trying to resolve an issue especially if uninstalling/reinstalling will resolve it. It's a fine line and each situation will dictate how much time I spend on it.
Just my two cents.
KyleEricson
  • May 12, 2020
@pbowden This script should work as well correct? Will this prompted users to quit Office apps?
https://gist.github.com/talkingmoose/a16ca849416ce5ce89316bacd75fc91a
PatrickD
  • May 14, 2020
I too am still seeing this issue after implementing a workaround from Jamf for a separate issue where Self Service installed MAS apps cannot update and you have to delete the app and reinstall it through Self Service.
PI-005189 - Self Service fails to display updates for Mac App Store apps if an older version of the app is already installed on the computer. Workaround: Use the Mac App Store to download the app update. ---- Which will only work if you are signed in with an Apple ID that has that app in its purchase history. Defeating the purpose of Volume Purchasing.
Jamf suggested setting the app to install Automatically and scope it to a Smart Computer group looking at a custom EA. That's when I saw the <MDMClientError:72> error. I have been trying to get Apple to give me an update on this issue for the last couple of months but all they are saying is "we only respond when there is a fix, which there isn't at this stage".
Personally, I think Jamf should be pressuring Apple on this issue.
  • June 1, 2020
Just want to post this as a quick workaround with Managed Apple IDs and pushing apps.
If you're getting this error, go ahead and get the user to open the App Store. They can click on their name in the bottom left, and a list of "purchased" apps will appear. Whatever app you licensed to them will appear there, and they can just go ahead and download/install it from the App Store itself.
I was experiencing this issue, and was diagnosing with a user. Was about to get them to sign out of the managed Apple ID and use a personal one, when I noticed this. Seems like the license gets properly assigned through the MDM, but the installation at the OS level fails.
This circumvents it, without the need of asking the user to hit "Install" until it just magically works the 100th time.
  • June 30, 2020
I've been keeping half an eye on this thread for six months or more after running into this issue with a few apps. I haven't really touched Mac App Store apps since then and I'm wondering if in a macOS 10.15.5/Jamf Pro 10.21 world, whether things are still messed up enough that it's not worth my time even exploring these apps or whether it's time to dip my toe back in the water and give it a shot? I find it hard to believe that the feature is so irreparably broken that it's useless but it's also pretty hard to believe how long this has been an issue with no apparent fix.
Thoughts?
  • June 30, 2020
@tzeilstra yup, still horribly broken I’m afraid.
  • July 8, 2020
VPP installations worked for us today... is this bug finally fixed???
  • July 9, 2020
Still broken... I had another 33 devices with VPP errors this morning...
  • July 9, 2020
VPP deployments and upgrades are both still jacked up ...
ImAMacGuy
Forum|alt.badge.img+23
  • July 10, 2020
ours were working for a while, just saw it broken again today.
  • July 10, 2020
It seems to be working occasionally, we are definitely seeing an improvement, usually the apps would not install at all, but currently we are getting VPP errors but the app will eventually install. We are using macOS 10.15.5 and Jamf Pro 10.22.1
ImAMacGuy
  • July 10, 2020
I had a user today that was trying to install a couple apps but were on VPN. I had them disconnect VPN and try again. The reported back that all apps installed as expected.
  • July 10, 2020
It is definitely a hit and miss at this stage... Still better than in the past. Apple you are on path to solving this...
  • July 24, 2020
I take everything back, as of yesterday we can't install any App Store Apps anymore...
bradtchapman
Forum|alt.badge.img+20
  • July 27, 2020
@jwojda : which VPN provider are you using? And is it split-tunnel or full-tunnel? Are you seeing this on all versions of macOS or just just the latest?
GeorgeCasper
  • August 12, 2020
We're having it here with iMovie and XCode. Nothing like trying to get software on machines for the start of the semester and having it inexplicably and silently fail...
  • August 14, 2020
Same here. sometimes they work and sometimes they don't. No solution yet.
  • August 26, 2020
This is still not working for us. Any one got this solved?
Thank you.
  • August 26, 2020
Still an ongoing issue for me too. Its a little less frequent, but i still see it often enough.
