You do not use one over the other, you would use them together as a method to streamline enrollment as well as tie user accounts to the mac they are using and Jamf Connect will keep the account sycned with your iDP.
DEP is not relational with connect, DEP being how your devices enroll into Jamf. Your options there are an enrollment config, manual enrollment or DEP. Connect is solely in relation to how you want your users to authenticate. Problem with LDAP/AD bind is the device makes mobile/network accounts on the mac that does not have security tokens. No Security token means no encryption (there are ways to do that still but they are not good solutions). Extra benefit maybe that your identity provider provides true off prem authentication were an being bound you would have a mobile account with a cached credential instead.
If you recently inherited Jamf Administration duties I highly recommend the training videos. If this is a new set up, waiting for your on-boarding training may be beneficial.
JAMF Connect and DEP are separate tools and functions with different purposes. JAMF connect does complement DEP extremely well if configured correctly.
DEP ensures a device is enrolled in to your MDM platform as a part of activation.
JAMF Connect is a tool used to sync your local accounts with your network accounts without the need to domain bind.
- Tools similar to JAMF connect. NoMad and Apple SSO Extension
- How JAMF connect can work with DEP. You can install JAMF connect during enrollment, and use JAMF connect to replace the macOS login screen so users can authenticate with Okta, ADFS, ext. From there JAMF connect can automatically build the user account based on configuration for a fully 0 touch deployment while maintaining access control.
