Whats the meaning of "Monitoring the File System" in Composer?
  • November 30, 2021
  • 33 views
Hi Im looking for composer as app packaging tool.
So I can understand when it needed "Normal snapshots" and the other snapshot.
But "Monitoring the File System" is not.
What is the appropriate case for this function? and how its different with snapshot?
I need your help Thank you
Best answer by mainelysteve
You mean monitor didn't compare before and after?
Just catch the changes in installation?
Thank you
Only during. It uses file system events to capture things like plist creation, directory creation, modification, etc.
Snapshots are before and after.
  • November 30, 2021
This should hopefully answer your question.
Essentially it monitors changes in the filesystem whilst you create the package. Snapshots are comparisons of before and after.
  • December 1, 2021
Thank you
  • December 1, 2021
Thank you
