Has anyone experienced WiFi taking precedence over Ethernet in macOS 10.14.5? We've seen that although the Mac is connected on Ethernet; set first in service order - the Mac uses the WiFi . This causes a lot of problems during enrolment in our case.
Grateful for any/all feedback.
I personally experienced this issue one time when I tried using the Internet Sharing service (macOS 10.14.4).
Eventually the Ethernet was shown at the top of the network service order after the WiFi was re-enabled manually.
We also requested our technitians not to use Ethernet when they enroll a Mac computer to MDM.
Out of curiosity, what hardware are you seeing this on? With the advent of T2 chips, I've found that I can't completely turn off wifi. It still gets an Apipa address which then triggers our security agents to want to block things.
