Hello,
I have been having issues with Casper skipping the Winclone file during images, I have Winclone 4 Pro and have followed the directions on the site, it skips the partitioning during the first step and also the last step the winclone file. we are running 10.7.5 and am not sure what the problem is. I also have made the image self extracting according to the directions help!
Thanks
Can you post a screen capture of your Casper Admin->Configuration->Additional Partitions screen?
If you look, in the JSS, at the Casper Imaging log for the client machine, what, if anything, does it say?
It is there - I haven't looked in the logs.
Solved,
Found the problem - wrong disk space.
Can you elaborate on "wrong disk space"? We are having the same problem.
bgreeno,
Go to your alternative disk on the Casper Admin and show me your Windows partition screenshot it here.
Nicholas
