"write defaults" script not running properly.
  • October 25, 2012
  • 22 views
Hey all,
Theres a command I am trying to use as a script but for some reason, it doesn't run. JSS shows the policy as successful.
defaults write /Library/Preferences/com.apple.NetworkAuthorization UseShortName -bool YES
We have tried running this script at logon and startup to no avail.
Thanks in advance!
Best answer by jdziat
Maybe try something like this out
#! /bin/sh
sudo defaults write /Library/Preferences/com.apple.NetworkAuthorization UseShortName -bool YES;
if [ -f '/Library/Preferences/com.apple.NetworkAuthorization.plist' ] then exit 0;
fi exit 1;
  • October 25, 2012
#! /bin/sh
fi exit 1;
  • October 25, 2012
#! /bin/sh
then
exit 0;
exit 1;
Sorry about that and the double post. You should be able to set up a managed preference for that as well
  • November 9, 2012
Sorry,
Sandy shut our district down for a week. The script seemed to work. Thanks jdziat!
