Credentials Required Twice for Zero Touch Provisioning
  • May 10, 2022
  • 27 views
Hi all,
We are setting up our Zero-Touch deployment and currently we are using Okta SSO to verify the users.
Our setup goes like the Following.
Sign into Apple DEP (Okta) > Sign into JAMF Connect > In to Laptop
Is there a way to streamline the process or pass through the Username and Password to JAMF Connect so that we don't require the credentials twice?
Thanks in Advance
RaxiaDK
  • May 10, 2022
JC?
Where is a setting to pash the password, this come in 2.12 JC
[JC-3808] When the Use Passthrough Authentication (OIDCUsePassthroughAuth) login window preference is set to true, the login window no longer displays a step indicator if there is only one step required.
edit
https://docs.jamf.com/jamf-connect/2.12.0/documentation/Release_History.html
Have a look at this session by @rabbitt from JNUC'21.
And this would basically be a tl;dr for you.
  • May 19, 2022
In the end we removed authentication in the Pre-Stage Enrollment and removed the enrollment customization.
This allowed us to only authenticate at the JAMF Connect screen.
