How does Jamf Connect detect that I have a network connection? We are starting to implement an always on VPN solution and I believe it is interfering with Jamf Connects' ability to confirm a valid network connection.
I have confirmed that I am connected to a wifi network, for some reason though Jamf Connect doesn't think I'm connected and will provide the Local Login option. The message on screen is "Your Mac is not connected to a network. Try using local login.".
Depending on how Jamf Connect is determining a valid network connection we might be able to whitelist or exclude it from the VPN solution.
