For some time I have had some strange issues with pre-stage and setting up new mac´s
I am using jamf connect and setup the package in pre-stage. All new mac´s are in the scope the sync between Apple business manager is fine.
I bootup a new mac and put in on wifi etc - and it also shows the management framework, that it is enrolled to company
Afterwards the jamf connect package should apply, but instead it sometimes jumps to local account creation(which I have disabled in pre-stage setup) - or it just shows the login screen with the management account I have setup in prestage.
If I wipe the device it may work fine the 2nd time, but it is so randomly. Anyone has seen something similar on where the error is ? So frustrating that a wipe sometimes is needed
