802.1x Ethernet to Connect Automatically
  • August 30, 2023
  • 37 views
I've created a 802.1x Ethernet configuration profile and deployed to a couple of test devices.
I can get 802.1x to connect going into Network - Ethernet Connection - Details - 802.1x - select Configuration Profile for Network and clicking connect. It auths via TLS and connects but i would like this to happen automatically, we cannot expect our users to manually go in and connect everytime.
Does anyone know how i get this to connect automatically?
TIA.
  • August 30, 2023
resolve the issue, had to include a username in the config profile even though we are using certificates for auth.
  • August 30, 2023
@infrase2020 even i have the same issue , if possible can you please share how did you fix the issue ? and also when a user uses a multiple adapters or network devices( Ethernet adapters ,docking station etc..) are you able to connect to 802.1x network ?
  • September 4, 2023
Nope, i thought i had fixed it but it doesn't automatically connect.
