802.1x Wired Network Configuration Question
  • October 11, 2017
  • 11 views
I've setup a Configuration Profile with a Network and Certificate payload.
When deployed to a test machine it works as expected, however the login screen now has a Drop down list
Ethernet: Network
None
Is there anyway to remove this dropdown list while still providing 802.1x?
1 reply
  • October 11, 2017
This comes with "Use as a Login Window configuration" setting.
