We are still testing Mountain Lion before allowing installation across our environment and wireless config continues to give us trouble.
We have WPA2 Enterprise security, and we use 802.1x network authentication via TLS (certificate based authentication), the certificate payload includes a wireless certificate and then root and corp certs in the trust. The profile is scoped at the system level for clients running 10.8+
The Config profile pushes out to Mountain Lion clients and they are able to connect to the network but they inevitably end up jumping on and off of the network, often when the screen is locked, which renders network users (Active Directory) unable to log back into their profile until they plug in to the network.
Anyone else experiencing this? If you are any ideas for a fix? I can barely maintain a wi-fi connection for more than a few minutes. Our Lion clients continue to work just fine with the same network and certificate payloads.
