ability to keep machine in static group after reimaging?
  • July 10, 2017
  • 21 views
ImAMacGuy
Forum|alt.badge.img+23
I'm trying to test some different DEP workflows, and I created a static group that I apply the policies and workflows to.
The problem is that after I re-image the machine, it drops out of the static group and I tend to forget to put them back in. Is there a way to keep them in the static group after imaging without going back into the JSS and manually adding them?
  • July 10, 2017
Are you deleting the Macs out of the JSS as part of your imaging workflow? Because if you are, it's normal that they would fall out of any Static Groups. Once a record is deleted from the JSS, it gets removed from any groups and won't get put back in them unless done manually or with an API script.
If you leave records in place, when they get re-imaged they should land back in any previous Static Groups they were members of before being re-imaged. The JSS pairs the machine back up by it's UDID and knows its the same Mac.
  • July 10, 2017
If you are testing out DEP workflows and using pre-stage (making an assumption), could you just use a smart group that would look for anything that was enrolled using that pre-stage? That way, even if you do delete the object, it will auto-populate that smart group because it ran through that particular pre-stage.
You can create multiple pre-stages so you can test multiple DEP workflows using a smart group for each pre-stage.
ex.
Smart Group name: <PreStage> enrolled devices
Criteria: Enrollment Method: PreStage enrollment is <PreStage enrollment name>
DEP workflows can then be scoped to the smart group.
Cheers!
-Dan
  • July 12, 2017
Try using a Smart Group containing the serial numbers of your test devices.
