AD Home Folder changes causing small issues
  • October 26, 2014
  • 4 replies
  • 25 views
Recently we removed all student storage and network home folders from our SAN. We now point all student AD account home folders to an empty (or NULL) path.
Since this change, all new mobile accounts on devices show with a blank (finder and self service only) dock. The default dock itself does not even load. I am under the impression that this is due to the change on the AD side, and the mac not finding the data it was looking for in the NULL directory.
Anyone know an easy way (without replacing student home folders) to solve this issue? While I do not mind showing users how to populate their own docks, it would be far easier to have the default dock load for the younger children.
Best answer by bentoms
Looking at https://developer.apple.com/library/mac/documentation/Darwin/Reference/Manpages/man8/dsconfigad.8.html
I think it's something like: ```
dsconfigad -sharepoint disable
bentoms
Forum|alt.badge.img+35
  • October 26, 2014
I'm guessing the accounts are local? If so, remove the mapping for the SMBHome from the directory utility plugin.
  • October 26, 2014
Know a fast way to do that (I assume there is a simple command that is avoiding my brain this early Sunday morning)? I can script myself if you point me in the right direction :)
bentoms
  • October 26, 2014
  • October 26, 2014
Indeed you are correct. ([-sharepoint enable | disable]) Thanks a ton for helping me to jumpstart my brain :)
