ADCS and JIM on same server?
  • June 10, 2019
  • 22 views
tdclark
Forum|alt.badge.img+21
I'm willing to try this on my own, but after the struggles we encountered getting our JIM working in the DMZ I wondered if anyone had attempted this successfully before I go down the rabbit hole.
Do you have your JIM and your ADCS on the same server/system? In the DMZ? Working reliably?
Any caveats I should look out for?
  • June 10, 2019
We have our ADCS and JIM setup this way and it has been working successfully.
  • August 8, 2023
Is your server still running both tools?  Just researching now as our use case will help to not have to create multiple servers.
