ADEPT Jamf Recon not working
  • March 28, 2018
  • 6 views
Hey all,
We're trying to implement ADEPT within our business currently to replace our old Zero Touch model, however we seem to be having issue with running the Jamf Recon to set the asset-tag, the username and department.
Looking at the xcode app, it comes up as: "do shell script "/usr/local/jamf/bin/jamf recon -assetTag (assetTagValue) -endUsername (usernameValue) -department (departmentValue)" with administrator "
This just doesn't seem to work. Any ideas?
1 reply
  • March 28, 2018
If you look in /Library/Application Support/JAMF/ , do you have a file called userDetails.plist? If so does it have the correct values in it?
