Posted on 04-29-2019 09:00 AM
Hi there, am reaching out to see if anyone has come across the same problem. With Macs bound to Active Directory using it's in-built plugin am finding in Safari when login into office 365 and you get the ADFS SSO prompt for credentials it does not work and will not accept the credentials. Now here is the interesting part when you unbind the Mac from Active directory and come to login to office 365 as a local user the SSO prompt for ADFS works and accepts your credentials. Wonder if anyone has come across the problem same as me and if there is a work round.
Posted on 04-30-2019 12:30 AM
Forgot to mention as well Chrome seems to work all time if bound to AD or not bound.
