Adobe Exit Code 7
  • June 8, 2009
  • 10 views
Hi-
Anyone else dealing with exit code 7 on CS4 deployment? Specifically, Flash CS4.
Thx
j
Jared F. Nichols
Desktop Engineer, Infrastructure and Operations
MIT Lincoln Laboratory
244 Wood Street
781.981.5436
talkingmoose
Forum|alt.badge.img+36
  • Community Manager
  • June 8, 2009
Date: Mon, 8 Jun 2009 15:51:12 -0400
I've had nothing but heartache and troubles with Adobe CS4's installer for
Mac. That's with running it manually (double-click) as well as scripted
installs. I won't even throw it into Casper.
Flash is one of a few known issues. I believe you need to make sure to
completely remove all CS4 components using Setup's uninstall command and
then also go into /Library/Internet Plugins to remove any Flash residue
there. For good measure, I delete any com.adobe.* in /Library/Preferences as
well as /Library/Application Support/Adobe*.
bill
William M. Smith, Technical Analyst
MCS IT
Merrill Communications, LLC
(651) 632-1492
  • October 9, 2012
I'm getting it when I try to use a Self Service install for a standard user, but it's working for the admin user...
