Posted on β10-17-2017 01:21 PM
Is anyone using Respondus Lockdown Browser in a lab environment? I've had a request to install it on the MBPs that we check out to students. My attempt to create a package and then deploy the software resulted in it breaking the administrator profile. Has anyone else been able to use it?
Posted on β10-17-2017 01:35 PM
We've been using it here. For whatever reason, they have it so you can't rename the package. If you rename it breaks the installer, for our case anyway. So your pkg should be named
Install Respondus LockDown Browser (x64c) <string of numbers here that represents your school>.pkg
Hope this helps.
Posted on β10-17-2017 01:43 PM
We saw that too. The code indeed has to stay in the pkg title. It also doesn't appear to be compatible with the ARD agent.
Posted on β10-17-2017 02:36 PM
Thanks for the information. I'll see if I can get it to work.
