Auto Device Enrollment
kehanopni
New Contributor
Hello my boss wants me to help setup auto drive enrollment for our devices in my org i never done anything like this before but i’ve been doing some research
and i am confused on the whole jamf connect, we have a prestage enrollment created when computers are added to the group that will put them through the auto deployment which has been giving us issues for a while now
my boss wants me to upload a jamf connect pkg file to the enrollment packages section on our prestage enrollment but i dont know how to do that
any help and advice on auto device enrollment within jamf would really help.
2 REPLIES 2
dmichels
Contributor II
You can do it three different ways:
  • Mac Apps - there is an option to install JamfConnect. pkg via Jamf App Catalog this way is great, because it it based on a Smart Group and will update automatically.
  • Pre Stage Enrollments - Enrollment Packages - you can add the JamConnect.PKG here it will install during the enrollment process
  • Policies - Create a Jamf Connect Enrollment Policy and make the Trigger on Enrollment
JamfAdmin2
New Contributor II
i am literally having the same issue the jamf connect window will pop up during auto enrollment and will just give us a spinning cirlcle and nothing will happen i would have to shut down the computer and then it will work as normal it is not a smooth process at the moment we have a prestage and a policy setup but for the prestage my manager slacked me the jamf connect dmg he had setup i wonder if by him sending it over to me can cause some sort of hiccup versus he just uploading the package on his end
