Autopkgr: FAIL_RECIPES_WITHOUT_TRUST_INFO Expecting value: line 2 column 1 (char1) Failed.
  • July 20, 2023
  • 6 replies
  • 60 views
I'm having issues with uploading to JAMF. Getting the error below.
WARNING: com.github.autopkg.grahampugh-recipes.jamf.zoom.us-pkg-upload is missing trust info and FAIL_RECIPES_WITHOUT_TRUST_INFO is not set. Proceeding...
Expecting value: line 2 column 1 (char 1)
Failed.
Any ideas on what could be causing this, and how to fix it?
Thanks.
sdagley
  • July 20, 2023
@cdlp2043 Did the upload ever work?
  • July 20, 2023
@sdagley Nope. Only locally creating the pkg.
sdagley
  • July 20, 2023
@cdlp2043 I can't use package uploads in my environment, so not entirely sure what would trigger that error, but did you create an override for the definition, or are you trying to run the original definition itself? If the latter try creating an override.
SMR1
  • July 20, 2023
I'm using the below recipe and it uploads to jamf and I don't get the trust error
  • July 20, 2023
@SMR Do you leverage SSO on you JAMF Portal? Because we do.
SMR1
  • July 21, 2023
We don't do SSO for logging on to the portal.
